Is MAP a backup for MAF failure? ('95 LT1)
I thought that the MAP/Speed Density "took over" if there was a MAF fault, but when I disconnect the MAF the engine dies immediately. When I disconnect the MAP/Speed density (MAF still connected), the MIL illuminates and both fans come on, but engine stays running.
If the engine stays running w/ the MAP/Speed Density disconnected, is there REALLY a MAF fault?
My TunerCat file does NOT have "Speed Density Enabled" 'checked'. If it is 'checked', does that mean it's solely running on MAP/Speed Density or that MAP will "take over" if a MAF failure occured?
'95 LT1/4L60e
Thanks!
But if it's connected I don't know that it will ever switch over to Speed Density, even with a MAF fault?
