I have a 95 vette with a procharger with the intercooler, I am wondering if anyone has installed the Alcohol injection pump under the hood? I have the under the hood unit that Alcohol Injection systems has been advertising. Hope someone has done this install. Thanks
I installed the pump and tank just above the radiator on my 85........don't know if you have room on yours to do the same...........space under the hood of a corvette is hard to come by.
I have the intercooler that is taking up the space in front of the radiator.
My pump is under the DS headlight. I use the washer fluid resevoir as my tank. Mine is a Blowerworks unit, though. It looks better now, I covered all the wires!
Well guy thanks for the suggestions, I was able to put the pump in the light well on the drivers side. I had just installed a new bumper that gave me more room in that area. One more question were did you hook your hot lead to your pump?
Can't remember off the top of my head. I know the trigger (rocker and alky ECM) is wired to the fuel relay, but I'll have to check on the pump wiring when I get home.
If memory serves (and it often doesn't), the pump power lead is wired to the battery junction just behind the battery...fuseable of course. I'll need to look it over just to be sure.
