Chip?
Old May 18, 2008 | 08:16 PM
snowmanmdp's Avatar
snowmanmdp
Default Chip?
Anyone switch out their chip to an upgraded one, If so is it worth it? My 85 has 107,xxx and the motor is like new under the valve covers and leaks no oil or burns no oil. It plain and simple is not as fast as what I'm hearing it should be. It will not even turn the tires over! :o
Old May 18, 2008 | 08:28 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
A chip is not a magic bullet for that car.
Old May 18, 2008 | 09:30 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
You can gain some power with an AFPR, cut lid with K&N and 160deg T-stat with fan switch.
And free flowing exhaust will net some nice power gains.
Also, bump the TPS base voltage and maybe base timing to get a little snappier throttle response.
Old May 20, 2008 | 03:31 PM
black85's Avatar
black85
I wonder if your cat is clogged or something. Mine was frying tire even when I got it, until the cat got clogged.
To Chip?
