Dash temp gauge reading 20 degrees high
Old May 18, 2008 | 08:40 PM
racers50's Avatar
racers50
Default Dash temp gauge reading 20 degrees high
After changing plugs on my 84 stock crossfire my temp gauge started reading in the 195 to 208 range. Always before it had stayed around the 170 range. I have a 160 thermostat.....Would pulling the battery ground and forcing a reset help this....I changed the block temp sensor and same result with the new sensor.....
I checked it with the computer to see what the computer thought it was and it was right on 175, right where it normally runs???.
