Please help, many problems with 93 LT1
Old May 19, 2008 | 03:50 PM
Wicked V6's Avatar
Wicked V6
Default Please help, many problems with 93 LT1
Well, I was told to post these questions on this fourm, please see the link below.
Prasad
http://forums.corvetteforum.com/show....php?t=2029195
Old May 19, 2008 | 04:08 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
You need to post 1 question at a time Geesh. Which answer did I give you did you not believe? Did you pull the codes? You gotta help yourself and provide info.
The door issue
Yes you can lube the lock slides although it is probably binding by the door handle button. You need to pull the door panel to do it. You need the factory service manual to do that or do some searches on it.
Old May 20, 2008 | 12:53 PM
schrade's Avatar
schrade
Originally Posted by Redeasysport
You need to post 1 question at a time .
Yup.
Old May 20, 2008 | 02:44 PM
MikeC4's Avatar
MikeC4
Flashing syslight could be your battery. A weak battery can cause a plethara of problems.
Old May 20, 2008 | 02:53 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Did you check to see if the fuel pumps were compatible?
The SYS light flashing could be a low battery or your CCM could be have connectivity problems with various devices.
There is a bar that runs between the lock and the lock switch, theese are known to bind.
As Red said, you need to post related questions in a post and create others for other problems.
To Please help, many problems with 93 LT1
