Cut-back spark plugs w/ Nitrous???
Old Dec 18, 2001 | 04:24 PM
NUckINg FuTS's Avatar
NUckINg FuTS
Default Cut-back spark plugs w/ Nitrous???
Will this work? I've already cut the grounds on all my autolite plugs (1 step colder obviously). Does anyone have a theory of why or why not this will work?
Old Dec 18, 2001 | 05:17 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Cut-back spark plugs w/ Nitrous??? (NUckINg FuTS)
As long as you did not cut them too far back or go over a .035 gap you should be fine.
Old Dec 18, 2001 | 05:23 PM
johndezman's Avatar
johndezman
the "kernel" of fire is less shrouded from (more exposed to) the main body of combustible fuel/air so you get a better start to the big bang.
Old Dec 18, 2001 | 05:38 PM
RatRacer's Avatar
RatRacer
Default Re: Cut-back spark plugs w/ Nitrous??? (johndezman)
The one thing you must do is run non-projected tip plugs. Projected tip plugs will lead to detonation and eventual melt down. NGK makes a nice plug for this application.
To Cut-back spark plugs w/ Nitrous???
By Michael S. Palmer | 2026-06-03 11:00:24
