Replacing steering wheel questions.
Old Dec 18, 2001 | 05:26 PM
tikiltd's Avatar
tikiltd
Default Replacing steering wheel questions.
Might be replacing my steering wheel. I am not a mechanic. Is it hard? Or how much does it generally cost to get it replaced? I need to send something to them as like a trade (core)? Any tricks I need to know?
I may have found a good deal on a wheel. Thanks people.
Old Dec 18, 2001 | 07:50 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Replacing steering wheel questions. (tikiltd)
:cheers: Assuning you don't have an air bag, removal is pretty straight forward, have had mine off twice..Let's see if I can remember...HMM! Haynes manual was pretty good on this one.
You'll need a cheap wheel puller
It's so easy, I forgot how to do it :rolleyes:
:seeya
Old Dec 19, 2001 | 11:41 AM
MDC9966's Avatar
MDC9966
Default Re: Replacing steering wheel questions. (jackdaroofer)
really easy as long as you have a puller. make sure your wheel is straight when you remove it and straight when you reinstall.
Old Dec 19, 2001 | 11:44 AM
Nathan Plemons's Avatar
Nathan Plemons
Yep, a puller is a must. Even if you have an airbag it's not bad, just be carful with it. I helped my friend replace his entire steering column the other day, when we were finished we put his old wheel back on, the new one was warped :confused: I know on his car the wheels are keyed so that it only wants to go on one way.. I'm sure you COULD force it, but why would you, it should more or less fall back into place.
[Modified by Nathan Plemons, 9:46 AM 12/19/2001]
To Replacing steering wheel questions.
