Carbed 85 fuel pump problem
Old May 22, 2008 | 12:24 AM
AZC4Guy's Avatar
AZC4Guy
Originally Posted by 86GoldProject
Way too much rubber hose to pass tech inspection, it's considered unsafe. and I used steel braided -6an line from earls. .
Ya, I got rid of all my rubber too... Earl's for me as well. I have an inline fuel pump and regulator mounted on the frame, behind the right front wheel.
Old May 22, 2008 | 08:34 AM
RacerX70CC's Avatar
RacerX70CC
a fuel pump block off plate wouldn't allow you to run a mechanical pump, all it would do is block off the boss that a mechanical pump bolts to. It wouldn't solve the crossmember interfearance problem at all.
Who needs a mechanical pump when the in-tank pump works just fine... that's how I did it (it's not rocket science)
Old May 22, 2008 | 11:47 AM
AZC4Guy's Avatar
AZC4Guy
It wouldn't work for me. I had a wet nitrous system so needed a pumpo w/ 2 outlets that could move the required volume.
Old May 22, 2008 | 08:43 PM
86GoldProject's Avatar
86GoldProject
If you read the rest of the posts you realize thats the point I was trying to make. I'm still confused about the reply about the blockoff plate.. no idea what that had to do with anything...
