Check it out. E-mail from original owner.
Old Dec 18, 2001 | 10:13 PM
lemans396's Avatar
lemans396
Default Check it out. E-mail from original owner.
This was sent to me from the original owner. I am the third owner. The second owner didn't know much as far as the technical aspects of the car, so I got in touch with owner number one.
HELLO SYMEON, THE CHARCOAL 89 YOU PURCHASED FROM JIMMY WAS BOBS CAR, THE OWNER HERE AT UNIQUE. HE KEPT IT FOR ABOUT 5 YEARS.
WE REPLACED THE SHORT BLOCK AT 49,000 MILES. SHORTLY AFTER WE INSTALLED ALL THE OTHER ITEMS. THE CAMSHAFT IS A GM GRIND. SPECS ARE 208/221 DURATION @.050 , 522 LIFT WITH 1.6 RATIO FULL ROLLER ROCKERS. THE LIFTERS ARE STOCK GM ROLLER WITH STOCK HOLD DOWN.
THE INTAKE BASE IS AN ACCELL WITH ARIZONA SPEED & MARINE RUNNERS, THE UPPER BOX HAS BEEN PORTED. WE INSTALLED A FUEL PRESSURE REGULATOR AT THIS TIME AS WELL. THE DISTIBUTOR HAS AN ACCELL MODULE INSIDE, WE RAN MSD WIRES AND AN INDEXED SET OF FR5LS DELCO PLUGS. WE HAD A CHIP CUSTOM BURNED FOR ALL THE UPGRADES WE DID. THE REAR AXLE IS A DANA 44 WITH A 3.45 RATIO, IT WAS BRAND NEW FROM GM. ALONG WITH THE HEADERS, AIR INTAKE, COOLER THERMOSTAT, HI FLOW MASS AIR SENSOR, THIS CAR RAN CONSISTENT FLAT 13 SECOND QUARTERS AT 104 MPH. BEST RUN IN PERFECT CONDITIONS THE CAR WENT 12.77 AT 107 MPH. I HOPE THIS INFO HELPS YOU.
Old Dec 18, 2001 | 10:15 PM
scorp508's Avatar
scorp508
That is awesome!! :)
Old Dec 18, 2001 | 10:17 PM
NASCAR314's Avatar
NASCAR314
Default Re: Check it out. E-mail from original owner. (lemans396)
Sounds like the second owner didn't know what he really had! :cool:
Hammer's Avatar
Hammer
Is that from unique corvette in Long Island?
Old Dec 18, 2001 | 10:21 PM
lemans396's Avatar
lemans396
Default Re: Check it out. E-mail from original owner. (Hammer)
Hammer, yes it is.
Old Dec 18, 2001 | 10:26 PM
AS84's Avatar
AS84
thats awesome. Sounds like it outta run pretty good!
Old Dec 18, 2001 | 10:36 PM
Hardcorvette's Avatar
Hardcorvette
St. Jude Donor '06-'07-'08-'09-'10
Default Re: Check it out. E-mail from original owner. (AS84)
Now that is the kind of news you want to hear from a previous owner! :cheers:
Old Dec 18, 2001 | 11:37 PM
lemans396's Avatar
lemans396
Default Re: Check it out. E-mail from original owner. (Hardcorvette)
Since the car is at 70000 miles, there is only about 20000 on the block and rear. Yahooooo!! :D :D :D :D
Old Dec 19, 2001 | 01:48 AM
lemans396's Avatar
lemans396
Based on the modifications and quarter mile times, how much horsepower would I have at the flywheel? I'm guessing around 300-320.
Old Dec 19, 2001 | 01:16 PM
35th's Avatar
35th
That's :cool:
Old Dec 20, 2001 | 02:38 AM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
You gotta like the fact someone cares about a car that much. :cool:
To Check it out. E-mail from original owner.
