d44 problems
Old May 21, 2008 | 10:33 PM
eaglebusman's Avatar
eaglebusman
Default d44 problems
I installed a set of 4.10's in the rear pumpkin but there seems to be a clearance problem. It acts as if the ring gear may be rubbing on the case (batwing). Was this a problem on these? Thanks, Hal
Old May 21, 2008 | 10:36 PM
STL94LT1's Avatar
STL94LT1
Yes, some of the housings need to be clearanced for the larger 4.10 ring gear. Mine didn't need the extra clearancing.
Old May 21, 2008 | 10:41 PM
_twisted_'s Avatar
_twisted_
just remember its clearancing not grinding
Old May 21, 2008 | 11:05 PM
eaglebusman
Don't really know the differance between clearancing and grinding???The material's got to go, right? Hal
Old May 21, 2008 | 11:45 PM
_twisted_'s Avatar
_twisted_
when your doing it, your grinding
when you talk about it, you clearanced it
To d44 problems
