I have a 96 CE that has had a chronic problem for several years now.
It will occasionally go into a mode where the door locks "flutter". Actually, what they are doing is rapidly unlocking - sometimes at a frequency of perhaps 20 x second, to as little as once every few seconds.
The problem might go two days without occuring (reciently it made a nine hour trip without once doing so). Then it might do it every time you drive it for days on end!
I've tried taking the key fob out of the car and that doesn't affect it, so it's not likely a bad fob transmitter. I've looked everywhere to see if there's a lost fob anywhere but have never found one.
Has anybody ever had this one? I can't believe I have the only C4 in the world with this issue.
Cire
buy a new switch, it's shorting or sticking .........I've replaced mine once.
Thanks. It's great to hear that you had the same problem. As an aside, did you? Also, which switch are you referring to? If it's the door switch, they both flutter. Can one affect the other?
Cire
Most likely it is the door ajar switch. You will notice the light on the dash will flicker also. Alot of times this happens after you wash the car. The switches are around 20 dollars. Do a search and you will find instructions with how to replace them with out removing the door panels.
It did and my interior lights would come on too. After it dried out there were no more problems. If your not getting the ajar light on the dash flickering too and your interior lights don't come on then my guess would be it is in the door lock circut.
There's a door lock control relay, too. Here's where a Factory Service Manual (FSM) is worth its weight in gold. Do you have one?
I do have one. The question is if the relay's the likely culpret. The only time the door locks don't function perfectly is when they're fluttering. When that's going on, the locks are too busy trying to unlock (over and over).
Sooo, is the chance that the door lock control relay is the problem worth trying to locate and remove it? Let me guess, it's located right behind whatever they sat on the assembly line first when the car was built, right?
Cire
Mine did it once a while back but I had been doing some interior cleaning and got some cleaner on the sensor in the door and jamb. When I washed the car the locks went nuts! Cleaned them with some alcohol and it was fine.
Just a thought...did you try reprograming the fob. Might help. ??
I reprogramed the PKE fob a year or so ago to no avail, but I'll try again. I assumed however that with the fob in the house (see above)and the condition continuing (when miles from home) that ruled out the PKE program. Maybe not however, since the function may be active and therefore capable of "misfiring".
Rregardless, to me that says there is a problem with the car's body circuitry somewhere..right?
Cire96
P.S. Somehow I just can't believe I have the only 96 C4 in the universe with this glitch!
I appreciatet the idea and I'd try it except for the fact that I put a new battery in a month or so back.
All ideas welcomed! Please keep them coming.
Cire
The door locks run thru the PKE receiver. One relay each per door. If the PKE is disabled completely, the electronic door locks will not work either. The way your door locks oscillate at that rate does not sound like a bad manual door switch to me. There’s probably a bad capacitor (or chip) in the PKE causing the relays to switch on and off at a rapid rate.
More than likely the PKE receiver is acting up causing the problem. If that’s the case the only real fix is to replace the PKE receiver. Re-programming, looking for codes, changing batteries and resetting the PKE probably won’t yield any positive success. Substitution is the only real way to know for sure which is a large effort. But that what it might take to get it working correcting.
Sorry, don’t have a quick fix for this problem.
By far the most informed idea yet! Thanks. As I recall the PKE has two recievers located somewhere in the rear of the car. Is that the case? I'm nowhere near my FSM to look it up just now. This hypothesis makes me wonder if I can unplug the reciever(s) and thereby isolate the problem?
If you have the coupe, then…..
There is one receiver which is mounted deep in the dash about center. The dash pad has to be removed to get to the receiver. The chimes box is mounted on top of the receiver. There are 2 antennas of which one is mounted in the drivers door and the other in the rear (center).
Yes you can unplug the receiver which will disable the entire power locks completely but will not really be isolating anything because it will all be dead. It will also take you the better part of the day to get in and out of there. You can do the same by pulling the fuses. Also if you ever take on the task, go slow and be careful because on 12 year old car the plastic is brittle (not like new). Don’t even try it with out a Helms the first time. It all comes apart but in a definite order.
In my eyes the only way to isolate the cause is to replace the PKE receiver. There are used ones around. No need to run to a dealer right away.
Thanks for the extremly insightful info. Sounds like I need to get out the service manual and start studying up...either that or just live with fluttering door locks.
Cire
P.S. Sounds like I may well have the only CE on the planet with this foible!
