Stroke'd Crossfire: is it possible?
I've thought about stroking the motor in my vette, and from what I've read, it seems that the crossfire setup is not suitable for a 383 stroker. Additionally, I've read on this forum that stroking the crossfire will require changes to the ECM. So that brings up a few more questions...
1. Can the crossfire system handle a 383 with ported intake and perhaps ported TB's? How about the injectors, can or should I get bigger ones?
2. Can the 2 bolt main L83 handle the torque that would come from a stroker? Would it need to be upgraded with splayed caps?
3. If I have to upgrade the ECM to handle the stroker, at that point, would it better to just upgrade to a different EFI system, since a new EFI would also require a change to the ECM? I'd rather not, since that can get even more expensive.
To help with answering my questions, here are my parameters:
A. I don't plan on going above 5K RPM ever. This is will be my regular daily driver, I don't plan on taking it to the track. I just wanna feel the power when I take off from a stoplight and when I'm driving on the highway
. It's also an ego issue, I want to be able to say that my car has 425-450 lb-fts of torque.B. I want the car to be emissions compliant. I'm moving to Texas, and they require smog testing on this type of car, so I want to keep the emissions features on it.
C. I want to keep all the electronic functionality in the car (dash, ac, power windows, etc.
D. I am leaning towards torque over horsepower
I welcome all comments, and thank you all in advance for them.
Keep on modding!
2-Bolt 383's are fine as long as they're built/balanced right and not abused too much. I've got a 383 out of my stock L83 block and it's fine.
ECM really depends on cam choice. I *think* you could get the stock ECM to run a 383 but you'll have to stick to a much milder cam. You'll be better off changing ECM's. The new EBL ECM's for the crossfire are much easier to tune than the old ones, but still a bit tricky if you've never done one before.
If torque is your goal, then the stock ECM and ported stock manifold can be used if properly mated to the rest of the components. Cam choice is the biggest issue. YOu might wanna talk to the guys over at
http://crossfire.home-ip.net
I'll break it down a bit. Your not looking to race the car right? Your only looking for a fun street car with some ***** is what I get from your parameters. That can be done quite easily.
All I asked is do you need it to be a 383. I'm pretty sure that you will find if you want that much horsepower you will need to tune. Don't expect to get that with your stock ecm. Just with my mods I've listed I'm tuning and thats only the 350.
I was only making a suggestion not a claim on hp/tq
I would suggest going to the crossfire forum to get some good input from those guys.
It seems that making this work (383 with stock ECM) comes down to the cam. Well, not just that, but it's one of the biggest players in this combo.
As far as a ported stock manifold w/ a 383 I think your pushing it. If your dead set on a 383 then look @ the X-Ram, but then again you'll need better heads as well.
If you are able to reach your torque goal, you'll also be looking for a D44 shortly after you grenade your D36 with that much torque.
http://www.crossfireforum.org
RACE ON!!!
Block: 383
Intake: Ported crossfire (I looked at the X-Ram, and it seems pretty expensive, and I'd lose low-end torque (MAJOR NO NO!), although, what if I put a plate down the middle of that huge port on the Weiand manifold?!)
Throttle Bodies: Stock
Cam: Crane Powermax 2030
Heads: Not sure yet, need input here
ECM: I think I'll just upgrade it, what the heck.
Aside from that, js292 gave me some good pointers on other mods:
Tri-Y Headers
2500 Stall Converter
3.54 gears (how about 3:73's, what's the difference?)
Dana 44
1:6 RR's
Free-flowing cat and exhaust: This brings up another question: Since I'll live in Houston, I need to retain the smog functionality, so, could I install a true-dual exhuast system (maybe twin cats) and still keep my emissions legality?
This is where I'm at so far. Anybody, please let me know what you consider weak points, if you know the answers to some of the questions above, etc.
Thanks again!
Now, about the gears, I've heard people who have 3.54's or 3.73's, and they each like them a lot. So what's the difference between them?
Also, I've just heard back from Stan at Stan's Headers, and he said they don't make Tri-Y's for 84 Corvettes, but I just found Melrose Motorsports, and they make an entire exhaust system (headers, x-pipe, dual cats, and rear pipes) for 84-85 corvettes that includes smog functionality (A.I.R., EGR, etc), so I think that's the best choice for exhuast mods and the closest I see that is emissions legal dual exhaust.
Back to the 383, I'm still not sure if it would be worth boring out the throttle bodies, if I'm keeping the ported manifold. What do you guys think?
http://cgi.ebay.com/ebaymotors/LT1-L...spagenameZWDVW
The Melrose set up is nice.
You don't NEED to upgrade the ECM, though doing so will allow you to custom tune, and FULLY optimize your combo. My car was a CFI Trans Am so it originally came w/the 165hp 305 CFI engine. I was running my 400 on the stock original ECM, w/the stock chip. It idled like stock, started in 1 compression stroke, and performed as described above. Also, My GF at the time didn't like the car b/c stepping on the gas "gave her whiplash"...in her words. It had sh1tloads of torque below 5k RPM.
Throw the CFI in the ditch if you want to maximize power. Why build a strong motor and hobble it with a sucky intake?
