From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Originally Posted by AGENT 86
What method determined that they were way off ??
Well, when the motor stopped I could wiggle the rocker with about 1/4 inch of play between the valve and the rocker tip. No way bleed down happened that fast.
I moved the motor a little by hand and got the same thing on the intake valve.
There was always a slight valve tap, but today they were loose.
Valves stuck? Did you check for compression? I remember you said you had a bang before the noise increase. Mabey the cylinder pumped gas through? Just a thought...
No gas in the oil. The valves move, just not nearly enough. It seems the exhaust may have only been opening 1/2 way.
There was no audible "bang" the use of the term was more to emphasize the fact that it happened suddenly.
Originally Posted by Pete K
If nothing loosened up, wear or breakage is the only thing that can increase clearances in a properly adjusted valvetrain.
We'll see later. I did not throw the final adjustment on the valves. When I had the new piston installed (in an attempt to have the car running for this weekend) I asked them to check the valve adjustments and do a final adjustment. So I don't know what could have happened.
When adjusting the valves, zero lash is sufficient to quiet valves. The 1/2 to 1 1/2 turns after zero lash is intended to put the plunger in the hydraulic lifter down .030 or more to account for wear.
I am not saying what happened to your motor, but it is true that a properly adjusted valvetrain that did not loosen the poly lock can only go out of adjustment with excessive wear or breakage. Bent pushrods and valves would fall under the breakage. Good luck either way.
HOw can I tell if a valve is bent. Seems to me that it would be pretty obvious.
You can remove the rocker arms to let the valves close, then put air into the cylinder. If it is bent even a little bit, it will not hold air. You will hear it blowing into the intake, or out the tailpipe, depending on which valve it is.
Another way is with the boink test.
Remove all of the rocker arms on the head you have the valve cover off of, and gently boink the tip of the valve with a small hammer. It will have a distinct feel, and sound. There is no mistaking a bent one.
.001 is enough to keep a valve from sealing. Almost nothing that goes wrong on a car is obvious. This is no exception. Unless you drive over a connecting rod, it is hard to see a hurt motor.
I have a fiber hammer for just such an occasion. I will boink it. Thanks.
Perhaps #8 was never adjusted right in the first place, as every thing looks OK from the top.
