New Trans Cooler, what ya think?
Old May 23, 2008 | 09:02 AM
Demonic85's Avatar
Demonic85
Default New Trans Cooler, what ya think?
JEGS extra high performance plate and fin design transmission coolers are 33% more efficient than similarly sized fin type coolers. Electrostatically powder coated for durability.
I'm thinking about mounting it towards the bottom of the radiator (front side of course). The one I got is 11" x 6".
Old May 23, 2008 | 09:22 AM
Pete K's Avatar
Pete K
Should be fine. Smaller coolers remove quite a bit of heat for their size.
Old May 23, 2008 | 10:15 AM
Steve20's Avatar
Steve20
towards the bottom-had me concerned in the beginning, but if it is a plate design, I guess it's tough enough for a few stones. Nice Cooler
Old May 23, 2008 | 10:24 AM
Demonic85's Avatar
Demonic85
Yeah its the nicest one they make without a fan. I considered the thin one you mount to a frame rail but this one has more surface area.
Old May 23, 2008 | 10:33 AM
rickneworleansla's Avatar
rickneworleansla
Looks a lot like my B&M only mines bigger.
70266 - SuperCooler rated at 20,500 BTU 11"x8"x1-1/2" (Racing model doesn't include installation components and has female 1/2 NPT fittings). Can also be used for all fluid cooling needs.
Old May 23, 2008 | 10:58 AM
Aardwolf's Avatar
Aardwolf
I'm not sure it's worth it without a fan. If you have a front booster fan, maybe mount it behind that and put a manual fan switch on it.
Old May 23, 2008 | 12:06 PM
rickneworleansla
It's definately worth it. I've been using my B&M for a couple of years now. It runs a lot cooler than the stock setup. Mounted in front of the radiator the stock fans draw air through it. My trans temps here in the south typically range from the 170's to 180's depending on conditions. I saw 19x once when a a fan relay was unplugged with outside temps in the upper 190's in stop and go traffic.
Old May 23, 2008 | 12:15 PM
Aardwolf's Avatar
Aardwolf
How much cooler then stock at a cruise? 180° plus 40° if this is pan temp, is still to hot. Mine will run 135° at cruise but 200° is no problem without a trans cooler fan in slow traffic and A/C on. I just bypassed the radiator and picked up a fan hoping to bring down the slow speed temp. Sometimes the cruise temp is to low even.
Old May 23, 2008 | 01:31 PM
mseven's Avatar
mseven
hhmmm...I'm in:
dim. 22+x 8.7 (approx.)
To New Trans Cooler, what ya think?
