1988 instrument cluster issue
Old May 25, 2008 | 03:29 AM
RatC4's Avatar
RatC4
Default 1988 instrument cluster issue
When I am driving, more usually at night, the cluster will go dark, the turn indicator and high beam indicator lights will light up also, the high beam headlights. If I gently tap the cluster everything goes back to normal. I have had it happen during the day as well but not as frequently. I would guess that it is a bad ground but before I open up the cluster, I thought maybe someone would know where to look. Thanks in advance.
Old May 25, 2008 | 05:06 AM
convas's Avatar
convas
This page may help
http://www.batee.com/corvette/dcrg/allbright.shtml
Old May 25, 2008 | 01:31 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
batee.com has the answer to your problem...
Old May 25, 2008 | 03:06 PM
RatC4's Avatar
RatC4
Thanks a lot. That is exactly what I'm looking for.
Old Aug 30, 2009 | 10:17 PM
golfnstuff's Avatar
golfnstuff
I've got the same problem with my 86, except tapping on the cluster didn't help. I've been told it's a classic "loss of ground" symptom. I'm hoping to find a loose connector at the cluster or further back. I don't want to open up my cluster unless I absoluty have too. I spent $350 for a replacement cluster and, naturally, the warranty is up.
To 1988 instrument cluster issue
