'93 ECM Failure: Dead Battery Results
Old May 25, 2008 | 09:40 AM
TedH's Avatar
TedH
Default '93 ECM Failure: Dead Battery Results
My brother-in-law owns a Ruby 40th anniversary coupe. Recently, after winter storage, he found the battery completely discharged. He had a new battery installed; same result... dead... completely discharged. They tried a 3rd... same result.
Off to a more experienced shop that diagnosed a failed ECM. It was causing a major drain on the battery when not running.
The solution proposed by the GM customer service was for the ECM to be rebuilt by a company that specializes in failed ECMs; they are no longer available NEW (according to GM customer service). So, the C4 awaits its rebuilt ECM. $600 for the remanufacture and 1-year warranty once installed.
Is this a common problem? This car has 44K miles, LT1, automatic in event that is relevant.
Thanks for your info/response.
Old May 25, 2008 | 12:43 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
What????
There is not any power going to the ECM with the key off.
2nd, $600 is totally ludicrious, SIA will rebuild them for $75.
How was the ECM diagnosed?
How long did it take each battery to die?
You have a short somewhere, you need to find another shop.
Old May 25, 2008 | 04:54 PM
L71Maynard's Avatar
L71Maynard
I agree that is too expensive for a rebuild, even the dealer won't charge $600 to rebuild an ECM.
BTW, Who or what is SIA and how do I contact them to rebuilt an ECM for a '92?
Thanks,
Dave
Old May 25, 2008 | 06:23 PM
TedH's Avatar
TedH
Thanks. I've informed him about SIA. $129.17 includes $50 core charge if ECM they send them is not rebuildable.
Not aware how much the dealer charged for core in that $600. They are expecting a portion back. Granted, the dealer is performing the removal/install and also transferring the vette chip (if they don't rebuild the existing ECM).
To find SIA, I searched on "SIA Corvette ECM". From what I found on the SIA website, they rebuild MANY makes and years of ECMs. Sounds like an incredible bargain. Almost too good a deal. For them to rebuild a Corvette ECM for $80 sounds unbelievable. Most places won't even diagnose a problem (granted the problem is assumed to be the ECM).
I will be interested to see if the ECM rebuild solves their problem (battery draining in matter of several hours).
What I found strange was they had to pay the $600 to the GM dealer upfront... they've not even taken the car to the dealer yet for the ECM removal for shipping of the unit to California for the rebuild.
Thanks for the info. He mentioned he may inquire on what he is getting for all of that $600. The vette will 'sit' at the dealer for a week while it waits for the rebuilt part.
Old May 25, 2008 | 07:26 PM
schrade's Avatar
schrade
I don't think so.
Discharge a new battery in a few hours? Again, I don't think so (not with out some noise, or SMOKE).
Old May 28, 2008 | 08:33 PM
GORACK's Avatar
GORACK
I just bought a ECM reman, it was $82 dollars very easy to install and remove. It was my 88 now it was programed also, bought it at Advance auto parts. Might be different for yours.
Old May 28, 2008 | 09:39 PM
pcolt94's Avatar
pcolt94
Simple test.
Get the battery charged and pull the ECM fuse. Then wait the appreciate amount of time and see if the battery is dead. If it is discharged, then probably it is not the ECM.
If battery is alive, reinstall fuse. Then wait again and see if it goes dead.
The believe the ECM always has 12 volts on it of keep memory alive and save what it has learned about fuel mixture. Long and short term fuel trim, block learns (BLM).
With the cars of today the computers always need voltage to them. That’s why we check the idle current of about 25ma (.025Amps). Always charge battery at least once a month when not in use.
Old May 29, 2008 | 12:52 AM
Randy93's Avatar
Randy93
St. Jude Donor '06
Sorry Pcolt, the ECM does not always have 12 volts. For memory it has maybe .5 volts to maintain memory. There is no way the ECM drains the battery, unless like I said there is a short. I find it hard to believe that a ECM would drain the battery in so short a time.
The ECM does not get a direct feed of power from the battery, according to the FSM, it gets the power with the key off through the CCM.
You have a grounding issue or short somewhere between those 2 places.
Old May 29, 2008 | 06:18 AM
Tom Piper's Avatar
Tom Piper
The ECM, like the CCM, does draw current at all times.
But, these computers draw much less current when the vehicle is not being run -- normally, they will not drain a battery unless it hasn't been used for months.
When these computers "wake" up during vehicle use, they draw more current than when asleep.
The ECM is supplied 12 volts from the battery, but the ECM has a regulator circuit inside that regulates the voltage down to 5 volts for most, but not all functions.
Tom Piper
Old May 29, 2008 | 06:29 AM
Road Agent's Avatar
Road Agent
Old May 29, 2008 | 07:51 AM
pcolt94's Avatar
pcolt94
Originally Posted by Randy93
Sorry Pcolt, the ECM does not always have 12 volts. For memory it has maybe .5 volts to maintain memory. There is no way the ECM drains the battery, unless like I said there is a short. I find it hard to believe that a ECM would drain the other batterys in so short a time.
I think if you check your FSM closer you will find two 12 volt sources to the ECM. One from the key as you said and one from another fused source to keep memory up. The fuse is not in the standard fuse panel. Memory needs 5 volts, not 0.5 volts which is regulated down from 12 as Tom pointed out.
I agree the ECM should not drain battery unless there is a high resistance short.
In post #1 TedH never gave a time frame when the other batterys went dead. It was not till post #7 that the assumption was made the battery wend dead in a few hours. And that’s what everybody’s been running with since. Post #2 asked how long but there was no answer to that question from TedH.
I also have to correct myself from my original post when I said to pull the fuse. It was misleading because the real fuse you want is under the hood (I believe) which is the one that supplies 12 volts power to the ECM all the time.
Tom Piper
GM indicates idle current (asleep mode) should be under 50 ma. I believe I measured 29 ma on my 94.
To '93 ECM Failure: Dead Battery Results
