Hard Braking
Old May 25, 2008 | 10:36 AM
twotone84vette's Avatar
twotone84vette
Default Hard Braking
Hi All,
Experiencing hard braking, no power assist, on start up on my 84. Once the engine gets warm, it's OK. Resealed manifold, replaced MC, booster, brake hoses at the all wheels, and bled brakes.
Any suggestions for tracking this down would be appreciated.
Thanks!!
Old May 25, 2008 | 10:48 AM
schrade's Avatar
schrade
How does it idle when warmed up?
I'm thinkin' you got vacuum routed wrong somehow, or it's not gettin' sufficient vacuum to the booster diaphragm...
Old May 26, 2008 | 05:45 PM
twotone84vette
Thanks for the reply!
It idles pretty smooth and at around 6-700 rpm. The braking improves aroun 180 degrees. I'm starting to lean towards a vacuum leak around the EGR.
Doesn't the EGR open around normal engine operating temp? Once the engine gets to temp it's Ok. When it's cold it's like trying to stop a car with unasisted drum brakes all around.
To Hard Braking
