Fuel filter problem
Old May 25, 2008 | 12:51 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Default Fuel filter problem
I am trying to change the filter and was having trouble. So I sprayed it with PB and let it soak and hour. Well you guessed it, I stripped the nut and the filter is still attached.
Anybody know of a way to get the nut off without buying a new fuel line?
TIA
Old May 25, 2008 | 12:53 PM
STL94LT1's Avatar
STL94LT1
Flare nut tool or Vice Grips?
Old May 25, 2008 | 12:55 PM
williammackean's Avatar
williammackean
St. Jude Donor '07
This is exactly why I am getting a set of plumber's wrenches before the next FF change. The last one was an exercise, especially once I realized that I used the wrong end of the combination wrench.
:o
Old May 25, 2008 | 02:58 PM
No Go's Avatar
No Go
You are using line wrenches, right?
Not sure of a solution...vice grip it from now on???
Old May 25, 2008 | 03:00 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Wish I had gone and got one, but no I was using an open end wrench.
To Fuel filter problem
