Burnoff diagnostics Code 36
Old May 25, 2008 | 06:20 PM
spitfire's Avatar
spitfire
Cruising
Default Burnoff diagnostics Code 36
Can anyone help me figure out what I need to do to fix the problem?
I have a burnoff diagnostics code 36 and need to know what to do to fix the problem.
I already took the car to a guy who found out what the code was but he wasn't sure what to do about it. He suggested some throttle body cleaner and a good run at high rpm to clean things out. I did that and the check engine light still comes back after a while.
I am frustrated by computer controlled technology. I hope it is something simple but I am afraid it isn't.
Old May 25, 2008 | 08:17 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
What year Vette??
Old May 25, 2008 | 08:22 PM
daytonaer's Avatar
daytonaer
I swapped my 1-4 shift skip relay for the MAF burn off relay and fixed my code 36. There are a few other possibilities but I would try swapping relays around first as they are the same.
Old May 25, 2008 | 08:55 PM
joeld's Avatar
joeld
Do a search for "code 36", open the first old thread. Flip thry it until you see a posting by agent86. He put in a link to the trouble shooting procedure for this.
Joel
Old May 25, 2008 | 10:18 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Here's the flow chart for code 36 from my 86 FSM http://members.shaw.ca/corvette86/Code%2036.pdf
Your 89's fuel pump relay is wired different, this schematic shows the difference.http://members.shaw.ca/agent86/89fuel%20copy.jpg
Old May 26, 2008 | 12:07 PM
spitfire's Avatar
spitfire
Cruising
Sorry.....it is a 89.
Old May 26, 2008 | 12:10 PM
spitfire's Avatar
spitfire
Cruising
Some good suggestions..........thanks everyone. Keep em coming if anything else is a posibility. I'll be busy for a while.
To Burnoff diagnostics Code 36
