The car has been convert to 134 in the past. The pressure in the system in normal or slightly above. The compressor will kick on. It is not blowing as cold as I would like it.
stick a thermometer in the vent, let it run on max ac for 10 mins with it in the vent, after 10 mins check your temperature and look up the spec for the car if the temps are similar there really isnt much you can do
if the pressure is reading slightly high it could have a overcharge and its not operating properly try step 1 first then take it somewhere and have them evac it vaccum the system and recharge it with the correct amount of freon
I agree but with a caveat.............use either a fan or drive the car while checking it to make sure you have air flow across the condenser.
