picture request please
Old May 25, 2008 | 09:41 PM
twotonethunder's Avatar
twotonethunder
Default picture request please
im trying to remove the engine bracket that surrounds the power steering reservour on my 84 so i can remove the reservour and replace it ive removed 5 bolts thus far and cannot see any more possible bolts
ive even removed the alternator and upper radiator hose to gain a better view of whats going on, i pulled the smog pump pully off as well and found one more bolt back there
im looking for pictures of the front of the motor with the engine brackets removed down to the timing cover and ones as it was being taken apart so i can get a feel for where the bolts are all at and how it goes back together and this haynes manual isnt doing that for me
Old May 26, 2008 | 01:38 AM
twotonethunder
nobody takes pictures when theyre rebuilding their motor?
Old May 26, 2008 | 05:28 AM
Happydad's Avatar
Happydad
I Do
Old May 26, 2008 | 10:56 AM
jhammons01's Avatar
jhammons01
You don't need a picture.
What is happening is that whole assembly is hanging on via the two hoses at the bottom.
That whole bracket and res come out together after you pull them free of the hose connection at the bottom. THEN you can get the plastic our from the bracket......
Turkey baster the fluid first.
I may have read your question wrong, does this answer your question?
Old May 26, 2008 | 01:30 PM
twotonethunder
thanks jhammons that does answer my question but i plan on taking the brackets off the motor and give them a quick sandblast and repaint them black
Old May 26, 2008 | 04:06 PM
CFI-EFI's Avatar
CFI-EFI
Does this help?
RACE ON!!!
Last edited by CFI-EFI; May 26, 2008 at 04:46 PM. Reason: A more reasonable sized pictire.
Old May 26, 2008 | 09:08 PM
twotonethunder
thats what i needed thank you a ton
To picture request please
