E Test Surprises
Old May 28, 2008 | 03:47 PM
black_89_vette's Avatar
black_89_vette
Default E Test Surprises
1989, 383, Super Ram, AFR 195 Eliminators, 230/230 0.598" on a 1.6 rr on a 110 CL.
Idle Video.
In car idle video.
RESULTS
SPEED ----- TEST ----- LIMIT ----- READING
40 KM/H ---- HC ppm -- 242 --------4
40 KM/H ---- CO% ----- 1.92 -------0.01
40 KM/H ---- NO ppm -- 2520 -------462
IDLE -------- HC ppm -- 300 --------24
IDLE -------- CO% -----1.5 --------0.3
THIS THING PASSES WITH FLYING COLORS
Tips and tricks ..... maybe someone could disconnect the ESC wire and during the idle test, raise the idle speed via the gas pedal to like 1400-1500 RPM instead of the engine doing 900 or so.
Yeehaw, good for another 2 years!!
** EDIT **
This was tested under the hot rod class, due to the engine not being offered as a production engine. But, this thing passes by 1989 standards easily.
Old May 28, 2008 | 06:40 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
With those munbers your car would be a Gross Polluter in California.
Old May 28, 2008 | 07:45 PM
PurtyLilC4's Avatar
PurtyLilC4
that sob sounds good
Old May 28, 2008 | 07:59 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
E Test Surprises
Jerry the smog nazzi numbers are all well and good but how about some dyno and track numbers...
Well if ya exhale you're a gross polluter in KA...
Congrats on the clean running engine...
Old May 29, 2008 | 07:10 AM
black_89_vette
Dyno and track numbers to follow.
The track numbers will basically just be for MPH cuz I'm afraid of putting sticky tires on it and grenading the rear end if I go for traction.
To E Test Surprises
