4+3 Problem
Old May 28, 2008 | 06:05 PM
F0RMULA's Avatar
F0RMULA
Default 4+3 Problem
always the first time i put in in 1st gear after starting it up, at about 1700rpms, the overdrive kicks on. i usually just put it in netrual and click it off real quick and its fine until i start the car up again.
now, the buttons not turning it off?
any idea whats going on here?
any help is appreciated.thanks in advance
Old May 28, 2008 | 06:12 PM
c4cruiser's Avatar
c4cruiser
A common problem is a failing OD switch on the shifter. It's easy to replace. Do a search on OD button for some info.
The OD on my 87 will go into OD in low gear depending on throttle opening percentage and low RPM. Slow speeds in 1st will allow a 1st gear OD.
Here's some information on how the OD operates based on the year. Note that the 87-88 is different in operation from the earlier year units.
Old May 28, 2008 | 07:23 PM
F0RMULA's Avatar
F0RMULA
thanks for your help. i checked out that site and did some research.
do you know of anywhere that sells od switches?
thanks again
Old May 28, 2008 | 07:50 PM
Yellow2015's Avatar
Yellow2015
First off, I like the color you chose for your vette.
Is your switch in the shifter or the console? The shifter switch is a little hard to find and more detailed to install then the console one. Search here for OD switch. There are plenty of threads related to this.
I'm not sure about the 87's but on my 88, until the engine reaches 123 degrees, it won't go into OD.
Old May 28, 2008 | 08:20 PM
F0RMULA's Avatar
F0RMULA
thanks
its on the shifter.
Old May 28, 2008 | 08:50 PM
Yellow2015's Avatar
Yellow2015
Originally Posted by F0RMULA
thanks
its on the shifter.
The shifter mounted switch is not easy to find. E-Bay might be the best bet. Before you do that though, when you press the button, does the OD indicator light come on? If the light comes on then the switch is good and the problem lies elsewhere.
Old May 28, 2008 | 09:06 PM
F0RMULA's Avatar
F0RMULA
where is the switch located on the car?
Old May 29, 2008 | 12:26 AM
Curveit's Avatar
Curveit
The usual cause is the Relay. It will also act erratic if the fluid level is too low. A switch; if broken, can be replaced by one from Radio Shack. Sorry,I don't remember the part#.
Old May 29, 2008 | 04:47 PM
F0RMULA's Avatar
F0RMULA
thanks guys.
i just got down to the switch and the 2 electric wires connected to it were both split in half, so im gonna assume thats why the button wasnt working.
is the fluid your talking about the same as the clutch fluid that goes into the master cyl.? where is it?
Old May 29, 2008 | 07:44 PM
c4cruiser's Avatar
c4cruiser
He was talking about the fluid in the OD unit. It uses 2 quarts of Dexron II/III ATF (non-synthetic).
Old May 29, 2008 | 10:35 PM
Yellow2015's Avatar
Yellow2015
thanks guys.
I hope you counted the number of turns it took to remove that "T" rod.....
Old May 31, 2008 | 10:25 AM
F0RMULA's Avatar
F0RMULA
i didnt have to disconnect the t-rod
it was split way far down past the switch
Old May 31, 2008 | 09:49 PM
Yellow2015's Avatar
Yellow2015
Buy a lottery ticket........you're one lucky sob...........
To 4+3 Problem
