From: One day you're a Comet...the next day you're dust... Arkansas
The FJ25 is a Standard Motor Products injector but I don't know the lbs. rating. You can call their plant for info. Also Summit carries some SMP products. They good American made injectors.
the 0280150223 is a bosch rated at the following: 21.35 lbs 224.4 cc/mn @ 36psi or 2.48 Bar
the D1810AA is a lucas 24lb at 43.5 psi .
the 5720D810 is a standard 24lb at 43.5 psi
all these injectors basically flow the same because the bosch at 43.5psi will deliver 23.92 lb/hr the lucas/standard are disc type and have a faster delay time than that old style stock Bosch.. You should really get a set of matched injectors. It will run a lot better. Use the 22 as a replacement if you are upgrading your fuel pressure reg to a later 3 bar (43.5psi). or get 24's if you are leaving the fuel pressure stock. .
thanks alot for the help. i'm planning on leaving the fuel pressure at the 36psi. i'm just trying to find out whats going on with this car because it barly idles and and when i rev it it goes really lean like 18+ afr's
you can have 1 or 2 plugged injectors.. there is no on the car test for that. Check the coils on each injector then make sure they are all firing with a noid light.
