94 security system electrical drain
Old May 29, 2008 | 02:49 AM
llesg's Avatar
llesg
Default 94 security system electrical drain
My 94 drains the battery in about 2 to 3 days.
the battery was replaced about 3 months ago (die hard)
So now its in the dealer,they said its something to do with an open circut in the security system and they would fix it for $393.00,somthing about tearing half the dashboard out.Also they said it may be a short.
Does anyone know anything about this?
How hard of a job is this ?
Thanks in advance.
Old May 29, 2008 | 08:10 AM
pcolt94's Avatar
pcolt94
If they diagnosed it, exactly what parts did they say are defective. The security system involves a lot of small pieces and the biggest is the CCM computer (central control module). It is mounted in dash, kinda center, to the right of gas pedal and slightly up. But I really have no idea what they are really talking about.
An “open circuit in security?” I would have to ask you in your words aside from the battery going dead, what does not work correctly on car, is something not working?
If they said it may be a short, that’s a real general statement and just does not give me a warm feeling that they really know what is wrong and going to figure it out after you say OK.
Hard to give a direct answer to how hard is this job is because we really don’t know what the problem is and the description they gave you is to loose the pin it down.
Before you tear the dash apart you should have some sort of idea where you are going. There are many ways of approaching the problem. A basic approach is measuring battery drain current and pulling fuses and look for a drastic change.
Old May 30, 2008 | 02:52 AM
llesg's Avatar
llesg
So I called the dealer today and asked for more info, He said we think its the anti- theft module but cant be sure untill they get into it. So basiclly they want 400 bucks to look and then who know what.
Anybody know a good corvette mechanic in the sf bay area???
Old May 30, 2008 | 11:19 PM
pcolt94's Avatar
pcolt94
This is not an answer to your problem but just some additional information.
The “anti-theft modules” name really is called UTD (universal theft deterrent). This system or function is a combination of the CCM and the PKE. The CCM is the heart of the system, but the PKE arms the system. They work together to make it all happen. I have no idea at this time if your root cause of the problem is in this area.
I don’t know how they could zero in on the problem but don’t know what is wrong. That is why I asked you what is not working correctly which might lead to the problem. PKE boxes go bad at what I consider a moderate rate. CCMs are very reliable but not familiar with either of these items causing large current drains (with out something else not working).
Old Jun 2, 2008 | 03:21 PM
llesg's Avatar
llesg
Thanks for your input !! The problem being that the battery is completely drained in two or three days. It is draining 420 mili amps.
Old Jun 2, 2008 | 04:02 PM
JAKE's Avatar
JAKE
Try pulling fuses one at a time to see if any of them effects the drain.
Someone posted a detail check procedure recently but I can recall if it was here or on corvetteactioncenter forum.
Jake
To 94 security system electrical drain
