Help to remove C4 89 tail lights
Old May 29, 2008 | 11:42 AM
jfrubio's Avatar
jfrubio
Default Help to remove C4 89 tail lights
Hello!!!
I need to change glass of two of my tail lights and I don't know how!! I don't know how to remove tail lights, I try it from the floor, from the rear plate... And is imposible!!!!
Please help me!!
Thanks and regards from Spain.
Old May 29, 2008 | 12:26 PM
anesthes's Avatar
anesthes
Originally Posted by jfrubio
Hello!!!
Please help me!!
Take the inner wheel wells off, and use a long extension and a swivel socket to remove the outer two tail lamps, then you can stick your arm in the hole to get to the inner two. Thats how I did mine. 20 mins.
Removing the 9 thousand little screws holding the cover itself on was a PITA. another hour.
-- Joe
Old May 29, 2008 | 04:23 PM
jfrubio's Avatar
jfrubio
Hi anesthes!!
Thanks for your answer, I will try it next weekend!
I saw your car transformation, GOOD WORK!!!!.
I also want to change my automatic transmission to manual transmission. ¿How much money did you spend on it?.
And the price of the turbo?.
Thanks for your time and best regards from Spain.
Old May 29, 2008 | 05:26 PM
anesthes's Avatar
anesthes
Hi anesthes!!
Thanks.
The 6spd swap will cost between $1600-1800. The supercharger can be done for under $2000. I've got more into the car than its worth.. hands down.
-- Joe
Old May 29, 2008 | 07:41 PM
c4cruiser's Avatar
c4cruiser
The easiest way is to begin by removing the rear license plate. With that gone, remove the backup light housings.
That will give you enough room to put your hand and arm through the license plate frame opening and reaching in behind the tail lamp housings (small hands and arms will help here!!)
Each of the lamp housings are held in by 2 10mm nuts. You should be able to feel them. Starting with the inboard lamp, remove the nuts using a 1/4" drive socket and gently push the housing out of the rear facia. Remove the socket. With the inside lamp out, it will be easy to get to the nuts holding the outboard lamp housings.
You will probably find that the bulbs are stuck in place in the socket. GM used a dielectric grease to keep moisture out of the socket and this grease will have dried up over time. The bulb may shatter or break when you try to remove the bulb. Use some pliers to remove the bulb base.
Clean the old grease out and carefully clean the metal contacts. When you install a new bulb, put a light coat of dielectric grease on the socket and install the bulbs. It would be worth it to replace all 4 bulbs at one time.
Old May 29, 2008 | 08:22 PM
Road Agent's Avatar
Road Agent
No need to remove the wheel well!
To Help to remove C4 89 tail lights
