Question about changing out stereo
Old May 30, 2008 | 12:30 AM
anthem74's Avatar
anthem74
Default Question about changing out stereo
I'm getting a new stereo and speakers installed soon in my '89 coupe and I have this question- Since I am getting the Bose system out do I need to rewire the car for an aftermarket stereo and speakers as a dealer told me or is it possible to go with the stock wiring and use one of those adapters to hook up to the new deck? Thanks in advance!
Old May 30, 2008 | 08:04 AM
Stewball's Avatar
Stewball
Last sunday I just removed my old Bose system from my 87 and put in an aftermarket set of speakers and receiver. I used the existing wiring for the speakers without any problems.
When I was at Circuit City a few months back they too told me they wanted to rewire but I didn't see any point to it at all the factory wiring would be fine since I wasn't going to have a high powered system added.
Old May 30, 2008 | 01:34 PM
PurtyLilC4's Avatar
PurtyLilC4
yeah, I used an adapter in my 90 with the Bose system, just a tip if you decide to go that way....once you hook up the deck, if you can only get sound from the radio, say you switch to cd and you get no sound, the Bose amp is turning off, you will need to use the power antenna wire as both the power antenna and remote wire. Just a heads up if you go the adapter route.
Old May 30, 2008 | 03:36 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Replaced my bose in 87 and complete rewire w/amp, no reason to use old wire with new power system...
Old May 30, 2008 | 04:21 PM
86GoldProject's Avatar
86GoldProject
I used the factory power wire and factory antenna wires and simply ran new speaker wires, sounds great!
Old May 31, 2008 | 10:20 AM
Yellow2015's Avatar
Yellow2015
I did mine 3 years ago. Once you determine which wires are for the amp and which were for the speaker (an fsm helps here), just use the latter ones. This also allows you to go back to bose if you ever decide to.
To Question about changing out stereo
