Need Help - Radio quit working on '95 LT1
Old 05-31-2008, 08:07 PM
corvette1987coupe
corvette1987coupe's Avatar
Default Need Help - Radio quit working on '95 LT1
I just finished replacing the brake power booster on my '95 LT1 and when I went to start it up for a road test my radio (Delco Bose Gold Series) will not turn on. It does display a SCV down in the lower right corner. I check two fuses for the Radio (ignition) & (battery) and the both look good. Any ideas?
Old 05-31-2008, 10:28 PM
schrade
schrade's Avatar
CD work?
Old 06-01-2008, 11:15 AM
corvette1987coupe
Default Help - Radio not working on '95
Originally Posted by schrade
CD work?
The CD will input and eject, but will not play. When I turn the on/off (SCV - VOLUME) power switch on, it displays SCV in the lower right corner. The SCV goes out when the on/off switch is turned off. Does that SCV message come on normally? I really have not noticed it before when the radio was working. I have only used the radio in the past and have not used the CD. There appears to be at least some power that allows the SCV message to be displayed. Any ideas are welcomed.
Luke
Virginia Beach
Old 06-01-2008, 12:51 PM
Corvette Kid
Large Impressive Member
Support Corvetteforum!
Corvette Kid's Avatar
Location: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Audio section
To Need Help - Radio quit working on '95 LT1
Quick Reply: Need Help - Radio quit working on '95 LT1
