dyno'd today..
Old Jun 1, 2008 | 10:06 AM
pr0zac's Avatar
pr0zac
Default dyno'd today..
not to happy about it..
mods. lt4 355, comp 280xfi, shorty headers, 52mm tb, no cats 3in slp exhaust, 30# svo's..
well it only put down 287hp/277tq? does that seem right.. no spiking or sounds of it running wrong. just ran a 12.7@111.9 with a 1.99 60 2 weeks ago? i would have thought it would be in the 330-340rwhp range? and i would think i would notice a loss in hp.. dunno.
Old Jun 1, 2008 | 10:40 AM
bobmic93's Avatar
bobmic93
SOMETHING IS WRONG WITH THAT DYNO. Your times indicate 330 to 350 rwhp.
Old Jun 1, 2008 | 10:56 AM
Dr. Evil's Avatar
Dr. Evil
CI 1-2-3-4-5-6-7-8 Veteran
CI-IV AutoX Champ
CI-IV Burnout Champ
St. Jude Donor '07-'10
236 241 .552 .547 113° with 1.6 rockers, is this the cam you have?
You should be making alot more power but more than that your trap speed seems very low. I trap 115mph with less mods and a smaller cam (the hotcam). What dyno was this done on? A mustang dyno perhaps? I know that the operator of a mustang dyno can input some variables that will make the numbers go up or down if they dont know what they are doing. FWIW, before I put headers on mine I put down 301rwhp on a mustang dyno.
I'm curious about the rest of your motor though, what compresion ratio, heads ported? Valvetrain? Who tuned it etc etc. What were your shift points and can you post a dyno graph?
Just my opinion but if you have no cats why not go ahead and run some longtubes? I had a catback with stock manifolds and went 112mph. With longtubes I went 115mph with no other changes.
Old Jun 1, 2008 | 11:18 AM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
I've got a bolt-on LT1 and went 12.9@109 put down 309hp and 339ft on a dyno jet before the long tubes. The tune is off or the dyno is not set up right.
Old Jun 1, 2008 | 11:33 AM
jakers's Avatar
jakers
St. Jude Donor '06
Old Jun 1, 2008 | 11:34 AM
pr0zac's Avatar
pr0zac
i just got a set of em longtubes in the mail two days ago.. and my cam is a 230/236 with .576/.571 lift but regardless.. its 10.4:1 compression cause went to forged pistons and the heads and intake are untouched as far as ported.. i have 10308 vavle springs and comp pro mags and a pcm for less tune. i have put maybe 50 miles on the car since its been to the drag strip and there is no difference in how the runs. i can post a graph later.. there is no afr graph though. but it was puffing bits of black smoke here and there as any car does. so i know it wasn't too rich or too lean at any point. i know the shorties are a big cork but i would think it would have dynod more than that cause i have beat cars that have dyno'd comparable numbers to their 1/4 mile times that were higher numbers than that. and have beat ls2 gtos at the dragstrip consistantly, granted tehy are heavier but its a comparison. btw it was a mobile dynojet. i will have better times this weekend cause i a getting slicks.
Old Jun 1, 2008 | 11:35 AM
pr0zac's Avatar
pr0zac
i am sure my pcmforless tune is in need of some help too
Old Jun 1, 2008 | 12:21 PM
856SPEED's Avatar
856SPEED
Well, I don't know but your trap speeds are suggesting a little more than the dyno is giving credit; trap speeds on the strip (1/4 mile) are the true measure of performance in my opinion....my 355 is trapping 111-112 but my tune is off and is running pig rich at WOT........I have not had a dyno run/tune since the miniram install...look at my mods.....
Oh BTW.....that trap was before the air pump delete too........I'm not sure how that will improve things, but........FWIW
Old Jun 1, 2008 | 01:06 PM
STL94LT1's Avatar
STL94LT1
This could be detonation, too much spark advance. Your trap speed is indicating ~330 rwhp.
Old Jun 1, 2008 | 03:36 PM
pr0zac's Avatar
pr0zac
another car dyno'd consistent with what it has previously dyno'd so i don't know. about the detonation.. it was small amounts of black smoke and if it were detonating wouldn't it have showed on the graph?
Old Jun 1, 2008 | 04:03 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
I think some datalogging is in order here. This is a common camshaft for pcmforless to tune, as I have a very similiar one in my 396LT1, 425rwhp.
The timing curves are probably close, and I run 11.1to1 comp, and LT's with an auto.
Puffs of black smoke do indicate running lean/detonating and the engine compensating.
I had this happen on a dyno and it turned out to be a loose O2 sensor wire. No check engine light or anything and it was intermittent, and dropped my rwhp to 365!!!
So, do a thorough look over, and check your engine at night with no lights to see if you can see if the plugs and wires are causing little sparks, or anything to verify no problems.
LT4 engines use OBD2 and they are very sensitive to misfires.
Ans check that everything is tight, O2 sensors, plugs, injector wires on correct, anything.
Just my 2 cents.
Old Jun 1, 2008 | 06:26 PM
pr0zac's Avatar
pr0zac
this has run the same since the day i put it together. i have rolled raced a 320whp car that i beat and recently raced a c6 and was dead even.. i had the crank angle sensor tuned off so if it is misfiring there is no way of detecting, just knock counts. i will have to plug it in to see if i can find anything out. but i have felt no loss of any sort. car sounds fine and runs strong. on a 100 shot i have literally ran off from an over 415+whp srt4 on 21#'s with a 57 trim from a roll. there is no way on earth that i would have beat these cars with 287rwhp as a baseline. i seriously think that the guy wasn't pressing the pedal down all the way.
Old Jun 1, 2008 | 07:45 PM
jonecap's Avatar
jonecap
Other than the shorty headers, you should have close to the same setup as me and Dr. Evil. Mine made 354 on the dyno, but it also traps 115 to 117 with an occasional 118. Sounds like you need a dyno tune!
Old Jun 1, 2008 | 08:10 PM
93 ragtop's Avatar
93 ragtop
There have been 2 different people on this forum that have had the same problem. Both of them turned out to be the timing chain was installed 1 tooth off. They both seemed to run fine but were way down on hp.
Old Jun 1, 2008 | 08:33 PM
pr0zac's Avatar
pr0zac
i know. like i said i got a set of EM long tubes in the mail that still need to be put on and the reason i went with them is because of how fast your car was going with them. i am already in the process of building a 383 for it and it won't be getting the long tubes with this motor.. i have only gone the the drag strip with this car 2 times so it was alot of learning. with slicks i should net much better results cause i can't come out of the hole with anything more then 2000rpms with my current tires.. with the slicks i will be able to really launch it and get the numbers it should be getting. i will be getting a dyno tune with the next setup for sure because that number is an embaressment and a dissapointment considering all the work that is done to the car was done by myself. and to have the dyno guy, not knowing one spec about my car, tell me that that number is about right for the car and that the dyno can't tell that its a corvette, i took everything in me to not hand him his teeth in a cup.
Old Jun 1, 2008 | 08:41 PM
96GS#007's Avatar
96GS#007
What kind of dyno? If it was a Dynojet dyno, you're way low. If it was a Mustang dyno, you're right on the money.
edit: Never mind, just saw it was a mobile Dynojet. Looks like the dyno was miscalibrated.
To dyno'd today..
