Have I been doing it all WRONG ????
Old Jun 2, 2008 | 07:40 PM
combustables's Avatar
combustables
Default Have I been doing it all WRONG ????
Hi Guys,
It suddenly dawned on me that I might have done something wrong.
I rewired my TWO very powerful 3000 cfm spal cooling fans, by taking a power feed directly off of the battery. The relay is triggered by the original signal from the ECM.
Should I have taken the feed off of the ALTERNATOR instead?
Somebody? CFI-EFI? AGENT86? BADUCK? STAUGER? Where are you guys?
Lee
Old Jun 2, 2008 | 09:35 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
I am pretty sure you did it right.
Old Jun 2, 2008 | 09:39 PM
Road Agent's Avatar
Road Agent
Old Jun 2, 2008 | 09:42 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
Originally Posted by combustables
Hi Guys,
Lee
Battery juction post with individual fuses and relays would work also. Did I miss a thread about why you need so much air. A stock cooling system will keep the temps normal.
Old Jun 2, 2008 | 09:50 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
The original setup was the same as your new setup, but the factory setup includes fusible links, one for ECM controlled main fan and one for coolant temp switched aux fan. Is there a fuse or fusible link between the battery and relay ??
Old Jun 2, 2008 | 10:19 PM
cbryant's Avatar
cbryant
Add a fuse or fusible link and keep it at the battery.
Old Jun 3, 2008 | 09:39 AM
combustables
Ok. Cool! (Pardon the pun!)
Thanks guys. I'll keep it at the battery and add the fusible link. So much air is needed because the damned 383 that fat dawg engines built me makes SOOOO much heat it's not even funny. I've got crazy power but can't idle anywhere worth a damn... Forget about air conditioning ...
Old Jun 3, 2008 | 10:01 AM
AGENT 86's Avatar
AGENT 86
I would use something like this, http://www.littelfuse.com/data/en/Da.../FH3Holder.pdf
Old Jun 3, 2008 | 10:27 AM
Randy93's Avatar
Randy93
St. Jude Donor '06
Originally Posted by Road Agent
Excuse me, I took it for granted he had a fuse inline. But, it was the right thing to do, so what is your problem?
Old Jun 3, 2008 | 01:01 PM
JAKE's Avatar
JAKE
Sounds like a tuning issue. My 388 LT1 never had that kind of heat problem running the A/C or not.
Bryan at PCMFORLESS.com did my tuning.
Jake
To Have I been doing it all WRONG ????
