1989 Idle Speed
Old Jun 3, 2008 | 10:16 AM
LT1 Rocker's Avatar
LT1 Rocker
Default 1989 Idle Speed
OK, I hear that the idle speed is not supposed to be adjustable in teh 1989 LT1 350.
Just replaced the throttle body with a 52 mm one with the air foil and the lowest RPM I can get it to is 800 with the idle set screw just contacting the throttle linkage plate. Also adjusted the throttle valve to .54 volts.
Does anyone know of a way to lower the idle speed? I read that 450 rpm is the correct speed.
Old Jun 3, 2008 | 10:22 AM
Fastcossi's Avatar
Fastcossi
Default Idle
Have you disconnected the idle air valve and the plug to cut the ignition advance?
Old Jun 3, 2008 | 10:32 AM
LT1 Rocker's Avatar
LT1 Rocker
Default Idle
No, but thanks for the tips. I will try to locate those and see what happens.
Old Jun 3, 2008 | 10:57 AM
Fastcossi's Avatar
Fastcossi
It´s a special procedure to set the base rpm of 450. It is discribed in the service manual. Do you have it?
As long the idle air valve is connected it trying to keep the rpm up to 8-900.
Old Jun 3, 2008 | 11:38 AM
LT1 Rocker's Avatar
LT1 Rocker
Default Idle
I will check it out in the manual. I have the GM, Chilton and another offshoot. One of them might help.
Old Jun 3, 2008 | 12:35 PM
Fastcossi's Avatar
Fastcossi
Look into the GM there is the correct description to set the minimun base idle of 450. If you do in that way it should work after
Old Jun 3, 2008 | 07:43 PM
cwyates4's Avatar
cwyates4
Is this an L98 engine or an Lt1? Lt1s did not come in the 89, the L98 did.
Old Jun 3, 2008 | 10:30 PM
schrade's Avatar
schrade
I second the question...
Old Jun 3, 2008 | 11:21 PM
Dads90's Avatar
Dads90
If it is a L98 check this tip out : https://www.corvetteforum.com/techti...D=55&TopicID=2
Old Jun 4, 2008 | 08:30 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Check it out. Lars's write up doesn't mention to disconnect the EST wire, but it should be done for best results. Here's a blurb from the manual. http://members.shaw.ca/agent86/TB-TPS%2bMin-Idle.pdf
The tan/stripe EST wire/connector is beside the brake booster (engine side)
Old Jun 4, 2008 | 09:17 AM
Fastcossi's Avatar
Fastcossi
I think in the GM manual - which LT1Rocker said to have - it is mentioned to disconnect EST.
To 1989 Idle Speed
