1985 corvette vacuum lines
Old Jun 3, 2008 | 09:52 PM
solaris_vii's Avatar
solaris_vii
Default 1985 corvette vacuum lines
quick question about my 1985 corvette. underneath the plenum there is a vacuum line that splits into two lines; one goes to the fuel pressure regulator and the other goes to the side of the plenum. i happened to break um.... all 3 of those lines when i rebuilt the engine, and i have replacement lines but the splitter is f*@#ed! while changing the oil today i noticed that there is an outlet for a vacuum line on top of one of the emision things thats capped off. could i just run the line to the side of the plenum off of that and then run the other line right to the fuel pressure regulator? i guess my short question could be does the order of the lines matter? or as long as there are vacuum lines hooked up, would it work? please let me know i have a car show saturday and i need to drive there. thanks for any help.
Old Jun 3, 2008 | 09:54 PM
John A. Marker's Avatar
John A. Marker
I would stay with the same vacuum line configuration. If you can't find a "y" at your local auto parts store...then go for a "T" and use a little extra hose.
