Block Drain Plug???
Old Jun 4, 2008 | 12:35 PM
Whitecloud's Avatar
Whitecloud
Default Block Drain Plug???
I am in the middle of changing my coolant and I can't find the block drain plug. The factory service manual doesn't tell me where it is. I need help. I have the radiator drained, is that all I need to do? Or do I need to drain from the block drain whatever and wherever that is? Help???
Read my last post and thanks everyone for sharing your knowledge and support.
Old Jun 4, 2008 | 12:43 PM
pianoguy's Avatar
pianoguy
On LTx engines, the block is drained by removing the knock sensors on each side of the block. Not sure if the L98 also uses this method.
Old Jun 4, 2008 | 12:50 PM
Fastcossi's Avatar
Fastcossi
On L98 block draining you have also to remove the knock sensor.
Old Jun 4, 2008 | 12:56 PM
Whitecloud's Avatar
Whitecloud
I can't find the knock sensor. Is it underneath the block or on the side of the block, and is that where the drain plug is also? Confused???
But I'm not giving up and will keep trying. Thanks for everyones help. Todd
Old Jun 4, 2008 | 01:21 PM
Aardwolf's Avatar
Aardwolf
On my year I used the knock sensor on the passenger side of the block, there is a metal heat shield over it if I remember correctly.
Old Jun 4, 2008 | 01:23 PM
Fastcossi's Avatar
Fastcossi
I think it´s near the motor mount rubber right side istn´t it?
Old Jun 4, 2008 | 03:03 PM
NEVRL8T's Avatar
NEVRL8T
There is no drain plug. The knock sensors are the drain plugs so to speak.
Old Jun 4, 2008 | 03:24 PM
Whitecloud's Avatar
Whitecloud
Oh! Well I'm tackling this after lunch. I'll let you know how it goes. Thanks again.
Old Jun 4, 2008 | 03:26 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
There is a drain hole on both sides of block(just after of lower center).
Drivers side has a plug or hose/nipple to oil cooler and pass side has the knock sensor in the hole.
Old Jun 4, 2008 | 08:58 PM
Whitecloud's Avatar
Whitecloud
When you disconnect the knock sensor is there a round white ceramic piece connected to the bolt that you have to unscrew to drain the fluid. And what size is the bolt?
Old Jun 4, 2008 | 10:58 PM
Whitecloud's Avatar
Whitecloud
Holy Crap!!! I found both drains. Unbelievable. The plug on the driver that is connected to the hose, was so old that I had to cut the plug and will buy a new hose tomorrow. This is just incredible, the amount of frustration and satisfaction that takes place at the same time. I will also call ecklers or mid america tomorrow to find out the size of wrench I need to loosen the knock sensor. One project turns into two and three and....well you get the idea. thanks everyone for your support and knowledge. Todd
Old Jun 4, 2008 | 11:42 PM
John A. Marker's Avatar
John A. Marker
Use an adjustable wrench or start trying box ends until you find one that works.
Old Jun 5, 2008 | 04:14 AM
Fastcossi's Avatar
Fastcossi
Also take care for the correct torque by mounting the knock sensor again. The knock senor is very sensitive and if mounting with inncorrect torque you can damage it....
Old Jun 5, 2008 | 09:20 AM
AGENT 86's Avatar
AGENT 86
Socket works on the knock sensor, as well.
To Block Drain Plug???
