Help - Fuel is being cutoff
Old Jun 4, 2008 | 12:49 PM
Rbuet's Avatar
Rbuet
Default Help - Fuel is being cutoff
I have a 1995 LT1 with 6-speed in which I just completed installation of a Golen 383.
On the 1st road test, I found it stumbled/hestitated at about 3000 rpm. Using DataMaster to log the driving session, I discovered that when it stumbles, Spark Advance is reduced to 16 degrees (typical value is 38-42) and the fuel is cutoff to the injectors (Base Pulse Width=0 and INJ DC = 0). Also 02 Volts on both sides go to less than 20. No error codes. Car runs good, but lean, until the above described events occur.
MSD Opti, wires, plugs, O2 sensors and ICM are all new.
I am trying to contact both the engine builder and chip tuner to discuss this, but I wanted to know if anyone has any ideas in the mean time. Thanks for your help!
Old Jun 4, 2008 | 12:54 PM
Fastcossi's Avatar
Fastcossi
Knocking events? Normaly the knock sensor is the one who reduces advance.
Old Jun 4, 2008 | 12:58 PM
Rbuet's Avatar
Rbuet
Default Knock counts
The knock counts are very low and not associated by time with the hestitation.
Thanks for the suggestion!
Ron
Old Jun 4, 2008 | 01:26 PM
schrade's Avatar
schrade
Doesn't the oil pressure sensor have the 'authority' to kill injector firing? (for when there's dangerous oil pressure drop)
Old Jun 4, 2008 | 01:33 PM
Rbuet's Avatar
Rbuet
Oil pressure is very good (60-80), as measured with a mechanical gauge and the gauge on the dash. Could it be the sensor failing intermittently?
By the way, coolant temperature never exceeded 200 degrees, as recorded by DataMaster.
Ron
Old Jun 4, 2008 | 01:44 PM
schrade's Avatar
schrade
Depends.
If there's redundant oil pressure 'readers' (analog/digital) one might be showing that oil pressure is good, but somethin' else is happenin' that is causin' the computer to lose its own 'read', so it's shuttin' down.
That's a stretch, but it IS possible.....
To Help - Fuel is being cutoff
