Going Carb on C-4
You realy lose nothing beside the TC lockup(easy fix) and a few MPG functions on the dash
You can fold the efi wires back on top of the bell housing if you are considering ever putting the EFI on. Unless you are really going to make it a hod rod, putting a carb on will lower resale value so having the stock parts on hand when you sel it wouldn't be a bad thing. I removed all the excess wiring on my own car... and don'r regret it.
I don't know about any step by step manual ekess but I'd be willing to help you with any questions/problems you had and I bet several other dark siders would be too./
I like carbs and I like Fuel Injection.
What I like the most is being able to troubleshoot a fuel injected car for someone that spent waaaay too much money on his setup, and knows nothing except how to write checks.
It's kind of a kick that my 25 year old car is injected, and gets over 30 mpg, spins the tires, and rumbles ondown the road.
I can't tell you how many people haave commented at the gas stations lately how terrible it must be to be constantly be filling up my car since it probably gets such poor gas mileage.
When I tell them it gets over 30 mpg, suddenly I must be a genius to be able to tune a sportscar to get that kind of mileage. it's funny.
I stop every couple days and put 4 gallons or so in it because the gas prices change daily.
I drive 50 miles a day through 25 miles of heavy traffic, and 25 of kind of open road.
That's the benefits of fuel injection, even if it is the preimitive batch fire style.
Anyway, since these cars have the technology, it would probably be a good thing to improve on it instead of removing it.
Think of it this way,
These must have been kick-*** cars before the bean counters cheapened everything.
Soooo it's up to us to restore them to kick -*** status.
In my book, the real benefits of the F.I. is the ability of the system to compensate for altitude, and temperature changes.
Sure it's a pain to disassemble and reassemble, modify, and work on especially when the car is hot, but it's a dream to drive when everything is working as it should.
usually if it's not working right, (and you discount distributor, wires, plugs, thermostat, water pump, and the engine long block) it's a sensor, vacuum leak, or fuel delivery problem such as a fuel pump, regulator, or injector.
usually only one thing fails at any time.
With a carburetor, the fuel metering, regulation, delivery, pump shot, mixture, etc. is in the carb.
It's smaller, less laid out, and usually simple to fix. but when it doesn't work right, you have to consider every system in a carb.
idle circuit, enrichment, acceleration, choke, idle bleeds, auxiliary annular boosters, secondary circuits, metering rods, jets, power valves, accelerator cams, throttle shaft wear, throttle blade timing, etc.
in reality, even it is in a smaller package, you still have to remove the entire underhood fuel metering device to deal with it.
In addition, the fuel will evaporate from the bowls when you let it sit for a few weeks.
There are trade -offs on both ends, but the intuitive tuner will be adept at both systems.
