Starter overheating
Old Jun 6, 2008 | 03:25 PM
edwin99's Avatar
edwin99
5th Gear
Default Starter overheating
I replaced my starter because it will not respond when it gets too hot. Does anyone know of a heat shield that could help with this problem.
Old Jun 6, 2008 | 03:33 PM
1989vette's Avatar
1989vette
Are you sure its not a solenoid problem? My starter solenoid gets stuck sometimes and you need to smack it once or twice to cure the problem. Not sure if thats your problem or not but its worth a shot.
Old Jun 6, 2008 | 04:03 PM
JonnyAngle's Avatar
JonnyAngle
Every auto parts store will have it. Summit, MAM, everywhere online too. Keyword: "Starter Wrap"
Old Jun 6, 2008 | 04:26 PM
edwin99's Avatar
edwin99
5th Gear
Default Thanks
It might have been the solenoid. A couple of wacks or letting it cool down generally worked. The starter I bought came with the solenoid so I just replace the whole assembly. Thanks for the "starter wrap". I want to do something if I can to prevent future problems.
Old Jun 6, 2008 | 04:38 PM
racebum's Avatar
racebum
posts above are good info and i totally agree. in my case, i bought a "lifetime" spray N prey starter from a local store. when it acts funny, new one goes in. header heat does do damage. i probably should get the heat shield one of these days.
Old Jun 6, 2008 | 10:00 PM
pcolt94's Avatar
pcolt94
Please fill out profile so we all know what year it is. And stating it won't hurt either, will get more accurate answers.
Now you say you replaced the starter. They usually come with a solenoid, so I’m thinking its new also. Did you have the same problem with old starter?
What are the real symptoms. Does it try to turn, click or make any noise. Is the solenoid getting the 12 volts when key is turned. Have you cleaned and checked battery terminals. An does it always, only happen when its hot?
Old Jun 7, 2008 | 11:17 AM
edwin99's Avatar
edwin99
5th Gear
I have an '89 coupe with 52K miles. The problem most often appeared when I had driven at highway speed for an hour or so on a hot day. When I went to restart the car there was no sound at all. I called AAA and by the time they got to me the starter had cooled enough to restart. A couple of times the tow truck operator knew of the problem and hit the started with a crow bar a couple of times and it started. Voltage has been OK. I haven't driven the car since I replaced the starter. I didn't have a problem the first 10 years. I bought the car new.
Old Jun 7, 2008 | 11:51 AM
Muffin's Avatar
Muffin
This problem has plagued GM starters for many,many years. Weak spot is the brass contacts inside the solenoid. Won't conduct when hot and have considerable age. There are solutions to the problem ranging from anew starter, new solenoid, solenoid rebuild kit to cleaning the solenoid contacts. Ideal solution is a mini hi-torque starter. My son drives an old Chevy truck. He carries an unopened bottle of Coke with him at all times. When the starter doesn't work he opens the Coke, shakes well and sprays the starter to cool it down. Crazy but it works.
Old Jun 7, 2008 | 05:26 PM
pcolt94's Avatar
pcolt94
Seems like the new starter could be defective. Would not be the first time this has happened.
To Starter overheating
