trans problem
Old Jun 7, 2008 | 02:38 PM
2005avtj's Avatar
2005avtj
Default trans problem
Trans problem
I recently took out my corvette trans and installed it into another vehicle (el camino) the car has no provision for the speedo hook up and no electrical connections for the lockup...I am having problem with the trans not shifting it seems to be stuck in 1st gear... i am thinking it has something to do with the lack of the other stuff like the speedo and the lockup...so i am going to buy this B&M lockup kit http://www.jegs.com/p/B%26M/748070/10002/-1/10733
i know it will fix some of my problems but is that the cause of my trans not shifting?
Old Jun 7, 2008 | 02:53 PM
toptechx6's Avatar
toptechx6
No one can help you unless you fill out your profile or at least tell us what year Vette!
Old Jun 7, 2008 | 03:20 PM
2005avtj's Avatar
2005avtj
oh excuse me i forgot.. it came out of 84 vette and it went into a 73 el camino
Old Jun 7, 2008 | 03:42 PM
aboatguy's Avatar
aboatguy
Call Dana at Probuilt, he's great to talk to and won't try to sell you anything. Best of all he will give you the straight scoop.
http://www.700r4l60e.com/
Good luck
\MIke
Old Jun 7, 2008 | 05:02 PM
janarvae's Avatar
janarvae
Dana's a great guy and the first time I talked to him was for over an hour, and I didn't even say anything about buying. I did buy his Street/Strip Kit and a 9.5" Vigilante Converter from him - I'm almost done with the rebuild. The OP should definitely give him a call.
Old Jun 7, 2008 | 07:31 PM
2005avtj's Avatar
2005avtj
thanks ill give him a call...it works out well too cause its 909 southern Cal area
To trans problem
