Battery tender use
Old Jun 8, 2008 | 12:28 AM
20mercury's Avatar
20mercury
Default Battery tender use
Question: Do you need to unhook the battery when you use a battery tender (say a 1 or 2 amp charger just to keep the battery from going dead when you let your car sit up for a few weeks) ???
This is for a 1993 LT1, but the question might apply to any C4.
Thanks.
Old Jun 8, 2008 | 12:37 AM
Spinner_89's Avatar
Spinner_89
My experience with and '88 and an '89 has let me to belive that removing the battery (or just unhooking the posative lead) will give you better results. These cars have a lot of electronics that need to be fed constantly. For a short time (2-6 weeks) if your batter is in good condition, you shouldn't need a charger of any kind. However, for the winter this is what I do with mine.
Old Jun 8, 2008 | 02:56 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Mine is on when ever the car is parked. I wired a quick disconnect permanently on the battery. Never a problem and the battery is always ready to go. Whether its parked for a few days or weeks.
Old Jun 8, 2008 | 05:40 AM
85 500 horse's Avatar
85 500 horse
You do not need to remove the battery. Simply attach the tender and you're good to go. Do NOT get a battery charger. You want a trickle charger.
Old Jun 8, 2008 | 05:52 AM
UNCLEBILL's Avatar
UNCLEBILL
I have done the same.....less strain on the alternator...
Old Jun 8, 2008 | 08:31 AM
Can86Z51's Avatar
Can86Z51
Right - you need a real 'Battery Tender-TYPE(low amp, automatic) that can be left attached to the battery for long periods, if needed.
Old Jun 8, 2008 | 10:01 AM
78pacer's Avatar
78pacer
Thanks.
If your batery is taking a crap after only a few weeks of non-activity, do yourself a favor and replace the battery. They are cheap enough and you don't want it to die miles from home.
Mike
Old Jun 8, 2008 | 10:21 AM
Can86Z51's Avatar
Can86Z51
Mike
When it comes to batteries, if in doubt - replace!
Old Jun 8, 2008 | 11:07 AM
20mercury's Avatar
20mercury
Much thanks for all of the great advice !!!
To Battery tender use
