Going home from work today I pass a slow truck and get on it pretty good. At 5000RPM car fells like it goes into neutral then revs up to 6200 or there abouts then shifts. The car is a 1992 auto with 2.59 rear and has 101000 miles. If the tranny is failing is there a good place to buy one and what mods would you include ie torque convertor Thanks Randy :crazy:
The answer to this would be decided by what you plan to do witht he car in the future. If you just plan to use the car for a daily driver with no major mods, just get it rebuilt at a reputable local shop. If you want an all out rebuild I would look into art carr or another one of the good aftermarket tranny/race shop type rebuilds. Hardened shafts, converter, better clutches, higher line pressure, etc.
Is it the 2 to 3 shift?
That will help pin down the area of trouble, but it sounds like the 3/4 clutches are going away.
As for Mods I haven't done any but it looks like for a stock to slightly built motor the 700R4 is a good thing with out a lot of build, just make sure the trans tech knows his stuff, and from all the posts on converters it looks like somewhere between a 2400 to 2800 stall is the ticket for makin the car more 'responsive' off the line, course you'll probably have some traction issues with that :)
The problem occured between 2nd and 3rd. I was looking to have a top end package installed in Jan 2002 by Moreperformance then. If this tranny is toast who other than Art Carr do you recommend. There is a company in Louisana that does 700R4 trannys but I cant remember their name and I think they call their tranny the rapture or beast. Any imput would be helpful Randy
