Reading the archives I see this P0300 code set mostly by bad plug wires followed by the opti and a few others. Many times it was a struggle to nail it down.Why I am searching on this code since my car does not have it is beyond me...... mabey the OP should have checked there.
....maybe my desire to have personal one on one attention far exceeds my desire to do yet another search, maybe my feelings that this is more than just an archive site and that people my have some personal NEW information or experience to share other than "Bob's Vette threw a P0300 in 2004". I now realize why I post less more and more everyday. Unless my sarcasm quota is getting low, then I log on for some punishment.
yes, I did a search.
yes, I have a FSM.
yes, I wave.
yes, I try to use proper grammar and proof read my posts.
no, I don't believe C5's have a fat azz, nor do I think other generations suck.
no, I would never take my car to the dealer for service work, I use my FSM and occasionally this site. Although it seems the friendliest place on here now is the lonely halls of the archives.
I'll keep you all posted on how my car fares with it's problem... for the archives sake at least.
.... Unless my sarcasm quota is getting low, then I log on for some punishment.
No you have more than enough sarcasm. When people give you suggestions and you come back with posts like your last it will not get you more in the future. No one is punishing you besides yourself. I don't see where you posted back on anything that was suggested and the results. "personalized" attention is available at the dealership for $90 an hour. When someone points out there are many different reasons for your trouble and mentions the archive it is because for free you can try and eliminate those and come back with some results instead of insults. CYA
Well it failed again, even worse this time. Failed everything in the driving test by a mile. Here is what I've done so far in this order:
1) Cleaned K&N and TB
2) Seafoam in the intake and gas tank and drove for 1 hour at highway speeds. Then added 3/4 tank of fresh fuel.
3) Changed oil and plugs to NGK TR55 platinum's
4) I had a random misfire code P0300 before I did all this but have not had it since.
The car actually seems to be running worse since I did all of this, it smells rich. The old plugs didn't look too bad, nice color, all pucks still there, gap was good. I noticed the biggest difference after I changed them (rich smell), but I am getting no new codes. I'm getting it scanned at a buddy's place next Wednesday, any suggestions before then? The car has decent power in first gear but seems to bog a bit going into second if I get on it. I'm going to do a thorough check for VAC leaks tonight, although I don't think there are any. Any constructive comments are welcome. Thanks
I'd also clean the MAF wires with spray MAF cleaner. I once had crazy BLM (108) readings due to K&N oil migrating onto the MAF wires. No SES code was set, but Diacom reported the low numbers.
A good spraying brought things back to normal.
Jake
I already told him to clean the MAF but he does not seem to be doing much to fix his trouble besides complaining.
If this isn't sarcasm I don't know what is. I have listed the steps I have taken so far and yes I forgot to mention that I did clean the MAF. I also said that the car is going for a scan on Wednesday, if that isn't helping to solve my problem I don't know what is. As for the P0300 I haven't had it since I cleared it as said in my original post and I have put a full tank of fuel through it since. After reading the FSM for awhile last night I'm going to go through and check out the fuel system tonight. I'll try to post the #'s from both e-tests later when I get home.
If the P0300 is gone it will probably pass emissions. Not sure how yours work but usually here in the states if a OBDII code is present it will fail automatically. There is a whole rash of things that can cause this generic code some listed in the FSM some not. My comment was a reflection of your" I did not find a thing spare me the search advice" you get what you give. If you do do a search and read all of the posts on the P0300 you will have somewhere to look at curing your problem. Mabey the thing that caused the code is better but not well and not bad enough to toss another code. You are correct a scan with Datamaster and a laptop might help narrow things down.
Don't worry. . . a lot of people share your sentiments.. . and suffer in silence. I concentrate on the good solid folks who would never post garbage like that. And it is garbage. After a while you ignore the ego maniacs and get whatever you can get from CF . You need tough skin on CF.
OK how many searches have you done on other cars to help people? I do it all the time to give valid and useful advice it is not an ego thing it is a CORRECT thing and willing to spend some time plowing through posts to find relevant info. You're right about one thing there is plenty of garbage posted here any more.
If you have/had a misfire at one cylinder, I think that has about zero to do with gas. That is electrical, unless I'm mistaken.
A gas problem would show AFTER the fire, at the o2's ...
Driving HC limit: 57ppm Reading:25ppm PASS
CO limit:0.32% Reading:0.20% PASS
NO limit:421ppm Reading:570ppm FAIL
Idle HC limit: 200ppm Reading:73ppm PASS
CO limit: 1.00% Reading:0.97% PASS
NO N/A
2nd Test:
Driving HC limit:57ppm Reading:133ppm FAIL
CO limit:0.32% Reading:0.48% FAIL
NO limit:421ppm Reading:1518ppm FAIL
Idle HC limit:200ppm Reading:110 PASS
CO limit:1.00% Reading:0.62% PASS
NO N/A
** I did find a Vacuum leak last night on the left side of the intake by the PCV valve, after I fixed it the rich smell went away. Hopefully that was my problem, but the scan on Wed should shed some more light. I cleared the P0300 code myself with a code reader, it is not stored in the history, and it has not returned, nor have any other codes appeared. I have 44lbs of fuel pressure with the key on, engine off. Engine running I have 42-43lbs. When I shut it down the pressure did not go down it stayed at 44lbs for an hour before I removed the gauge.
It idles very smooth and even better now that I fixed the Vac leak. I pulled the tube off and could hear the engine rev up a bit and then back down, like it was compensating for the problem. I could hear just a tiny bit of a stumble at the tail pipes when the tube was off and a rich smell would come after about 30 seconds. Hopefully my problem is solved.
If the 300 is gone, fixing the vacuum leak probably fixed the problem. The air that gets sucked in through the leak is not measured by the MAF and it runs lean which sets up the lean misfire, which sends combustion temps up, which creates NOX. Scanning should now show that fuel delivery is correct for the air the MAF says it's getting. If so, it should pass (or it needs a new CAT).
How did you make out with your e-test. I have a 95 firebird LT-1 and it is failing nox also. I am in London where did you get your e-test? I can't get my plates until I pass. Please help.
