Y-Pipe "easy" to replace?
Old Dec 22, 2001 | 12:11 PM
flyinace2000's Avatar
flyinace2000
St. Jude Contributor
Default Y-Pipe "easy" to replace?
Hello,
Come January 2nd i will replaceing my rear y-pipe on my 84. Considering mine has quite a few rust holes, it is time. My question is how much experiance is needed for this job. I will be doing this in AutoShop class. We have a lift and everything. Any tips you might have would be greatly appreciated.
Will
1984
Old Dec 22, 2001 | 12:44 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Y-Pipe "easy" to replace? (flyinace2000)
If the rear of the cat bolts up to the Y it should be rather easy, cut the bolts and replace them.
Separating the Y from the mufflers could take some ingenuity but can be done.
On a lift with a good tool set it should be rather easy.
I would get new hangers and clamps to facilitate the job.
If you want some added power, replace the stock Y with a 2 1/2" - 3" mandrel-bent system, depending on the cat interface.
Old Dec 22, 2001 | 01:18 PM
LPDesRoche's Avatar
LPDesRoche
Default Re: Y-Pipe "easy" to replace? (65Z01)
It's a very straight forward job. There are 2 bolts holding the pipe to the cat, and 1 clamp per muffler holding them to the pipe. No hidden tricks. But the odds of getting your stock mufflers off the old pipe and fitting them to the new pipe may leave you wondering. More than likely they are rusted to the pipe and will have to be cut off. You may have to get them welded back on or either get new ones.
To Y-Pipe "easy" to replace?
