hot engine no start
Old Jun 13, 2008 | 09:57 PM
t00ms's Avatar
t00ms
Default hot engine no start
my car is a 1989 coupe with a 6speed manual trans with 70000 miles. ok i changed the plugs, wires, cap, rotor, icm. car started up and ran fine. turned the car off went to start car about 5 mins later and would not start. the car will start when cold but once the car reaches normal operating temp the car wont start. did a fuel pressure test and it was fine so i dont believe i have any leaky injectors. took tb off and cleaned it also pulled iac and made sure there was no carbon buildup. i am at a lost on what to do next. any help will be appreciated. btw the computer shows no codes at all.
Old Jun 13, 2008 | 10:00 PM
cwyates4's Avatar
cwyates4
I was going to suggest injectors, but you seem to have ruled out that possibility. What does it do when it won't start? If you give it some gas, will it start? Have you checked for the presence of trouble codes?
Oh, and was this occuring before the work you did to the ignition system, or did it start afterwards?
Old Jun 13, 2008 | 10:11 PM
t00ms's Avatar
t00ms
ther are no trouble codes. the engine just cranks when i try to start. i tried pushing the pedal all the way down and than tried to start but nothing. it happened before i changed everything and it was suggested to me that it was the icm but that doesnt seem to be the problem. i really dont want to be changing everything on the car. i have a fsm and been trying to trouble shoot the problem but everything i try doesnt seem to fix problem. i know it is probably staring me in the face but i just cant see it.
Old Jun 13, 2008 | 10:37 PM
FICINJECTORS's Avatar
FICINJECTORS
Supporting Vendor
check the injector coils.. We see multecs all the time that will fire when cold. but as the coils get hot they will not work, Ohm test each injector and post the results.. Never rule out a multec!
Old Jun 14, 2008 | 12:11 AM
jfb's Avatar
jfb
Check for spark, hot ign modules and/or hot spark coils fail when hot when they get old or put out a weak spark. You should easily see a 1/2 inch snappy spark at the plug wire. Put a noid light (available at parts stores), or a low power 12v lamp like a 194 side marker lamp across an unplugged injector wire and crank, you should see the lamp pulse.
Old Jun 14, 2008 | 05:33 AM
RRT vette's Avatar
RRT vette
Old Jun 14, 2008 | 03:56 PM
t00ms's Avatar
t00ms
ok i ohmed tested the injectors they are as follows, cold readings are 1,3,5 read 16.1, 7 reads 15.8, 8 & 6 reads 12.2, 4 reads 14.7 and 2 reads 16.4
the hot readings, engine temp approx 200 they are as follows 8,4 & 3 read 8.1, 6 reads 7.5, 2 reads 8.9, 1 reads 14.1, 5 reads 16.7 and 7 reads 6.5. I also did a fuel pressure test and it read 41.5psi and held after about 30 mins it dropped down to about 30 psi .
I also put a light on the injector connections and they all pulsed as the car cranked.
Old Jun 14, 2008 | 04:18 PM
davenbocafl's Avatar
davenbocafl
run a jumper wire from the pos. battery to the batt. on the distributer cap, that will eliminate alot of questions (after its hot)
Old Jun 15, 2008 | 12:10 AM
FICINJECTORS
Supporting Vendor
with those ohm readings below 11 hot, you need injectors. Without a doubt.
Old Jun 15, 2008 | 02:00 PM
rick lambert's Avatar
rick lambert
Old Jun 15, 2008 | 02:07 PM
t00ms's Avatar
t00ms
injectors it is, anyone have any recommendations on which ones to get and where to get them. and also thanks for the help guys.
Old Jun 15, 2008 | 04:41 PM
edwardpayne's Avatar
edwardpayne
Hi, I'm new to this part of my car.
The Injectors.. are they changing resistance when they are hot?
My car is weak as a 100 hp car after some hard driving. Can't rev it to more than 3500rpms. I checked the injectors when it was cold and they all were from 15.0 to 15.3 ohms.
Old Jun 15, 2008 | 06:56 PM
FICINJECTORS
Supporting Vendor
someone else asked the same question
http://forums.corvetteforum.com/show....php?t=2046748
Old Jun 16, 2008 | 08:14 AM
shamdave's Avatar
shamdave
My did the exact same thing! if the fuels drops off quick afte you shut it off, it is the fuel pump Mine did the exact same thing its a 50.00 fix and easy to do.
Old Jun 16, 2008 | 11:18 AM
Randy93's Avatar
Randy93
St. Jude Donor '06
Was the car running fine before the tuneup?
I find it hard to believe that FI's could be good before the tuneup and bad after. Did you use dialectric grease on the ICM?
Old Jun 16, 2008 | 07:09 PM
blck90vette's Avatar
blck90vette
tooms,,(1990 vert) ,i bought 8 injectors from FIC. 1-770-888-1662,, ask for Jon,,,will help you out,,,great customer service,,,
Old Jun 16, 2008 | 07:42 PM
t00ms's Avatar
t00ms
I just ordered the injectors from FIC. Spoke with Jon, very nice guy and really takes the time to explain everything to you. Hopefully when I install these injectors problem is solved to which I think it will be. Will update post after injectors are installed. Thanks to everybody for the help and info, I really appreciate it.
To hot engine no start
Old Jun 23, 2008 | 05:11 PM
t00ms's Avatar
t00ms
Just to update everybody on my car, I bought injectors from Jon at FIC and was able to put them in yesterday after several hours (haha) and now the car runs better than ever. No more problem starting it up after its hot. I would like to thank everybody on here especially Jon for all their help. I dont think people really realize what kind of information is on this site. There are so many people here that are willing to help if we just ask for it, and anybody that is going to check their injectors remember to ohm them cold and than ohm them hot cause you might be surprised.
Old Jun 23, 2008 | 05:26 PM
schrade's Avatar
schrade
None in HISTORY either?
ed. : delete...
Old Jun 23, 2008 | 06:44 PM
schrade's Avatar
schrade
The above post was my #3000 post (this one is actually #3010).
And I was about to delete the post.
