Long story short, installed miniram on a 1990 convertible 134,000 miles. I am shure there are no vacume leaks, distributer is in right/timing is correct/damper has not slipped. There are no codes. Fuel pressure is correct. This is what the car is doing. Sounds like there is a miss, and when driving the car backfires, stumbles, etc.. Full tuneup was performed right before mini install, new injectors installed(had multitechs) allthough they they all ohmed out at a good value. What should I look at next? I am trying to get a scanning device also.
timing or the distributor is a tooth off. normally a tune would be a good idea since the car will be rich in the lower range due to the slower airspeed of the mini but it should not be causing anything that big. check the dist & timing.
Thanks for the replys, I have a chip from pcmforless, with or with out the chip it runs the same. I also changed timing around just to see what it would do and had the same problems. After reading other threads and talking to Alvin at pcmforless I am going to keep it at 6 degrees BTDC.
Ok, I was able to borrow a tech 1 the other day and the only problem I saw was the TPS at full throttle was only at 4.16v, idle was good at around .54v. The FSM says full throttle should be at 5v +-.5 , so could the lower full throttle voltage cause a problem?
On $8D it doesn't really matter. It will trigger PE at 70% of throttle, which is 70% more than whatever the voltage was at key on. Its a little smarter than early masks.
Your problem is $8D and a miniram. On $6E and $32B (maf) calibrations it almost works so/so, but on speed density the map won't trigger enough AE quick enough and you'll get a pop through the intake, a stumble, etc.
(i've only done this about a dozen times)
The miniram is like a singleplane, it wants TONS of AE. If you were doing your own chips I could tell you what tables to edit and an idea of how much to throw in, but it really needs to be driven, logged, tuned, logged, and repeat. You can't tune a car from a thousand miles away.
Your problem is $8D and a miniram. ..........(i've only done this about a dozen times)
if I added up every tweak I did, it would have been at least 200..
You can't tune a car from a thousand miles away. Joe
true, despite popular belief....not to mention all the other contributing factors. I'm sure someone will jump in here and talk about their great mail order tune
Hey Brother!
Hows the project coming?
I think out 'ac delete thread' died
Anyhow, yeah, he needs some tuning. I think a ton of AE will probably make it bareable, but overall someone needs to spend some time redoing the VE tables, then advance, then maybe VE again heh..
I am just starting down this road, I cant believe how huge the changes are for a 383 MR combo.
I'm going to be pick your brains guys, dont run away
I love tuning MAP based systems, but they are NOT forgiving to changes.
A short runner intake is a huge change
MAF systems are a lot more forgiving. A lot of people settle for 'its running fine' but in reality its a turd. This is probably why we see soo many expensive builds in the 13s when they should be deep in the 12s.
And don't even get me started on the guys who think all you need to do is raise fuel pressure and turn the dizzy.
Hey Brother!
Hows the project coming? I think out 'ac delete thread' died
-- Joe
good, thanks for asking...have you been working the dash/cluster set-up?
I was surprised to see that thread still lurking. I'm going through the steps myself (new Stewart cw. pump et all).
Yeah, I had some serious time in my tune before I could actually say it was done....of course, until the next drive Even after I had the tune nailed, then it was working the mat v.s. mat stuff for temps. (now there is a fun table)....it never ends. Now I'm getting ready to start all over again w/the new one.
My problem is, every time I drive the car the laptop is my only passenger, and is set-up w/emmu.
Same here. 10 miles. pull over, review logs, make changes, 10 miles, and so on. I've got most of it dialed in but I don't want to do any Wot/PE stuff Until I have a few hundred miles on the new clutch. Got about 80 now. Wot is easy though, its part throttle and AE that needs the most refinement. My MAT and Coolant temp vs spark tables keep me out of trouble. Under a 'perfect scenario' I can run *** kicking advance, but if it gets too hot it will retard it back down. Which in away is counterproductive as advance actually helps keep things cool (reduced EGTs) but once the cyl is already hot I don't want to risk detonation under boost.
I'm gonna do the cluster in oct. That way if I run into problems I can push it on a trailer and forget about it until the spring.
I am getting the urge to do some custom programming on my 87. Hopefully, I can learn a bit from this thread.
Tequilaboy is the man to talk to on the $32B stuff. I'm awfully impressed with what he has done on his current setup. The stuff he's doing with the ford MAF really throws the 255 g/s limitation out of the water.
If you ever want to run map, I'll help you repin the harness but you'll lose your DIC. (mpg, range, etc).
