Headlight Assembly Removal C4
Old Jun 17, 2008 | 12:39 PM
Uptospeed's Avatar
Uptospeed
Default Headlight Assembly Removal C4
The headlight motor on the passenger side is in failure mode – the motor continues to run at shut off and makes a noise.
The motor on the driver side was replaced a year or so ago.
Has anyone done a headlight assembly removal on a C4?
What are the basic steps?
I read the sticky, which is helpful but as far as I can tell it applies to earlier models.
The steps are probably very similar to the C4 though.
Also, there is supposed to be a manual override for opening the headlights.
Where is it and how does it work?
Old Jun 17, 2008 | 03:47 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Did you peep this Corvette Fever article? What year C4 do you have?
http://www.corvettefever.com/howto/33098/index.html
Old Jun 17, 2008 | 05:04 PM
Uptospeed's Avatar
Uptospeed
Very nice...very helpful article (I just started skimming it but will read the whole thing soon).
Now I can tell how much technical skill is required.
I have a 2000.
If you come across anything on the manual override, I'd appreciate it.
Thanks for the info.
Old Jun 17, 2008 | 07:20 PM
louisjames's Avatar
louisjames
I have a 2000.
in my manual it says rotate **** clockwise to open. any good to you?
Old Jun 17, 2008 | 08:36 PM
rodneyiii's Avatar
rodneyiii
Cruising
I have a 2000.
That's not a C4.
Old Jun 17, 2008 | 08:43 PM
louisjames's Avatar
louisjames
his question refers to c4 procedure.
Old Jun 19, 2008 | 06:58 PM
Uptospeed's Avatar
Uptospeed
Originally Posted by rodneyiii
That's not a C4.
You're right. I have a C5 but for some unknown reason typed C4.
Old Jun 20, 2008 | 09:30 AM
onedef92's Avatar
onedef92
Sorry, bud. Can't help you. Post your query in C5 General and you'll get your answer.
Old Jun 22, 2008 | 07:07 PM
Uptospeed's Avatar
Uptospeed
Will do.... Thanks anyway.
Old Jun 22, 2008 | 08:59 PM
IrishMac's Avatar
IrishMac
Moderator Emeritus
Gone, but not Forgotten
Cruise-In 5, 6, 8 & 10 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09
Wrong section..
To Headlight Assembly Removal C4
