Cam Question....
Old Dec 22, 2001 | 11:59 PM
OrangeC4's Avatar
OrangeC4
Default Cam Question....
I am thinking about finally changing the cam in my vette. Does anybody have any suggestions for a good cam for an L98?
Old Dec 23, 2001 | 12:01 AM
vader86's Avatar
vader86
Default Re: Cam Question.... (OrangeC4)
Accel 219 or ZZ-9 from TPIS, thats what i'm going to do. Depends on what you want from the car and what you want to do with it.
Old Dec 23, 2001 | 12:06 AM
OrangeC4's Avatar
OrangeC4
Default Re: Cam Question.... (vader86)
I am looking for a cam that is good for all around performance I guess. I am going in the direction of building my car to be a killer on the road course. Forget this 1/4 mile stuff, it isn't as fun.
Old Dec 23, 2001 | 12:17 AM
OrangeC4's Avatar
OrangeC4
I am also installing a miniram too, so I would need one that would have good compatibility with it.
Old Dec 23, 2001 | 12:19 AM
danno85's Avatar
danno85
TPIS has some good "recipes" for engines using their mini-ram - I'd take a close look at those if I were you. Get a copy of their Inside Hints book, it's got some good info in it.
Good luck!
Dan :)
Old Dec 23, 2001 | 12:22 AM
OrangeC4's Avatar
OrangeC4
Default Re: Cam Question.... (danno85)
Thanks guys. I will check these out. :cheers:
Old Dec 23, 2001 | 12:25 AM
LPDesRoche's Avatar
LPDesRoche
If you are going to use the Mini-ram, I would use the ZZ-9. Especially if you are using the stock heads. The ZZ-9 was designed for the stock heads. the LPE219 is more for aftermarket heads and the super ram.
Old Dec 23, 2001 | 12:32 AM
vader86's Avatar
vader86
Default Re: Cam Question.... (LPDesRoche)
yeah if you want the miniram, id look at what they have used with it. ZZ9 is supposed to work very well with the stock valvetrain
Old Dec 23, 2001 | 12:45 AM
OrangeC4's Avatar
OrangeC4
I just got done looking at that one, its specs are pretty impressive. I think that is the one I am going to go with.
Old Dec 23, 2001 | 12:54 AM
john25's Avatar
john25
Your car has a hydraulic flat tappet cam. The ZZ9 cam is a hydraulic roller cam. Are you going to switch over to use a roller cam? If you are doing the conversion take a look at the LT4 Hotcam. If you're going to stay with a flat tappet cam take a look at Comp Cams Extreme Energy lineup.
To Cam Question....
