electric water pump ??
Old Dec 23, 2001 | 12:50 AM
YellowC4's Avatar
YellowC4
Default electric water pump ??
is it good and how much hp gain and how long does it last
[Modified by YellowC4, 11:51 PM 12/22/2001]
Old Dec 23, 2001 | 12:59 AM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: electric water pump ?? (YellowC4)
My first one about 500 miles. As for HP gain ??????? I don't know. :confused:
Old Dec 23, 2001 | 01:04 AM
Bob86ZZ4's Avatar
Bob86ZZ4
Default Re: electric water pump ?? (mackeyred96)
My good friend is a top notch ASE mechanic, and races a car a lot like mine (he has a 6 speed, a bigger cam, and Hoosiers, and he is a much better driver than I and he kicks my butt every time) and he said don't put in an electric water pump. His main concern is that the mechanical pump we now have is very reliable and he doesn't think the electrics can match that. You may also be aware that the alternators on a C4 are not the most reliable either, so why tax them with more amperage draw?
Old Dec 23, 2001 | 05:51 AM
corvette90's Avatar
corvette90
Default Re: electric water pump ?? (Bob86ZZ4)
i don´t think an electric waterpump helps much to performance..
it needs amperage from the alternator, and the alternator takes more power from the engine..
so-im summary the same energy amount..
Old Dec 23, 2001 | 11:12 AM
95vettski's Avatar
95vettski
Some dyno results have showed an increase of 8-11hp in the upper rpm range. The real benefit of the electric pump is you can use a standard chevy double roller chain instead of the more expensive unit from GM. :cheers:
Old Dec 23, 2001 | 11:29 AM
MVR 155's Avatar
MVR 155
Cruise-In XI Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Default Re: electric water pump ?? (95vettski)
Just about every dyno test I have seen has resulted in about 10rwhp, it is also handy for cooling your car in the staging lanes or pits at the track. I will most likely be installing one over the winter.
Mike
Old Dec 23, 2001 | 03:48 PM
ASRoff's Avatar
ASRoff
My only response to this is "how long does your electric fuelpump last?" I have one on my Ford ranger that has 230,000 mi and is still going strong The mezinere pump is built much more stouter than a fuel pump. Ive had mine for a year and 2 months now without any problems. My So called "reliable" mechanical water pump went out at 40,000 mi. leaked all over the opti-junk. :seeya
Old Dec 24, 2001 | 01:17 AM
Bob86ZZ4's Avatar
Bob86ZZ4
Default Re: electric water pump ?? (ASRoff)
That's fine then, put in an electric water pump like ASRoff says. I don't care to argue about it. He simply asked what people thought about them.
Old Dec 24, 2001 | 01:34 AM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
I put one on for my latest buildup. I did my homework and expect a 5-10 rwhp gain across the board. I will know more once it is up and running. They should last fine as long as you get a good one in the first place (unlike John M). As with any mass produced item, they have a certain percentage of units that will fail early. They are rated to last 2000 hours I believe.
Old Dec 24, 2001 | 08:43 PM
dizwiz24's Avatar
dizwiz24
The power gain of about 10 HP, and most importantly torque is proven...
but...I decided not to get it, following the advice of my mechanic, about how if you blow a fuse, hook it up wrong, or have electrical problems, you'll end up overheating your engine, and damaging it.
I think you might be able to find in the archives, some people's experience (lcvette I believe, correct me if I'm wrong please) with what happens when the fuse blows on an electric water pump.....
I wanted to be able to drive my car on long trips without having to worry about the water pump fuse blowing, or how I'd get it fixed if it did.
Although I would have loved the extra power increase on top of everything else I did
Old Dec 25, 2001 | 06:51 AM
mrvette's Avatar
mrvette
Seems to me that IF you get 10 hp gain at clutch, then the water pump is taking 7500 watts.....at 14 volts figger on...that computes to...536 amps draw....uhhhh guess what???? that's more than the starter motor....
so IF you want to figger on 12.6 volts....the amps is.....595 amps...can't win the math discussion.....somehow somwhere a claim is WAY THE HELL OFF BASE HERE.....that load would fry most any alternator, even one from a fire truck.....
GENE
Old Dec 25, 2001 | 01:31 PM
Smitty's75's Avatar
Smitty's75
Ya got the same problems with electric fans and fuses/relays!!! So whats the worry, it doesn't keep you from using them!!
Everyone can try to gigure this one out mathmatically with the amp/alternator formulas,,but the bottom line is:
Race teams use them BECAUSE THEY MAKE HORSEPOWER.
The Mezier pump will LAST A LONG TIME on a street car. Read the articles where they were TESTED in most of the MAJOR magazines (Hot Rod, Car Craft, and Chevy High Performance). They have always been a recommended item because of their power potential, and longevity. Don't believe what you here from people here or you mechanic, research the articles where they were tested and form your own opinion,,,go to a drag strip and talk to the racers in the money and see what they're using...talk to John M or any other EXPERIENCED racer and ask why they use them,,just my 2 cents. There are past LONG threads on this subject and people keep throwing all those alternator/amp/watts or whatever formulas out there, but however you see it,,the dyno don't lie!
Old Dec 25, 2001 | 01:58 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: electric water pump ?? (mrvette)
Nunbers don't lie, but they CAN be misapplied. A mechanical water pump absorbs more power as the speed (rpms) increase. An electric water pump runs at a constant speed. It is my belief that the water pump speed at 5 or 6 grand, or wherever your horsepower peaks, is far in excess of what is needed to do the job. The electrical (Watts) horsepower equivalent of what the mechanical pump absorbs is by far in excess of what is need by the electric water pump to do the job.
On the other side of the coin. Most of the guys at the track that are "in the money" aren't driving their car TO the track or on cross country trips.
Just $0.02 more to add fuel to the flame.
Old Dec 25, 2001 | 02:24 PM
vanduker's Avatar
vanduker
Default Re: electric water pump ?? (dizwiz24)
My neighbor and I both use the electrics, both drive the cars every day (sun/rain/snow) and haven't had any issues except the car running cooler, making more power and getting better mileage. My neighbors pump has been on the car for two years, mine only ~ 6 months.
Something to keep in mind on the pro/con game is that changing a fuse really isn't the end of the world (and you do have two temperature gauges and a warning light if it fails). The Mezere will not puke coolant all over the OptiSpark - I'd rather change a fuse than a pump and Opti.
Mark
Old Dec 25, 2001 | 02:34 PM
mrvette's Avatar
mrvette
Default Re: electric water pump ?? (autoxer)
Drag race teams use them for HP gains, true enough,...BUT, in a street driven car cruising on the highway at 80 mph in 100f temps with a/c on...guess what??? now a more decent comparison would be NASCAR....500 miles flat out in sometimes 90f days....do they use electric pumps???
GENE
Old Dec 25, 2001 | 02:47 PM
vanduker's Avatar
vanduker
Take a look at the impeller on a stock pump. Not exactly high tech. Add to that the pump has an operational range of ~700 to 6500 rpm. Seems a lot to ask of any pump to be cheap (why is the impeller stamped sheet metal) and also operate optimally over such a wide range. An electric pump has a machined aluminum impeller and is optimized for a single speed.
I don't have a Winston Cup rule book handy, but electric pumps are banned in most forms of NASCAR.
Much like antifreeze, turbochargers, superchargers, nitrous oxide and fuel injection.
Mark
Old Dec 25, 2001 | 03:01 PM
KYVette90's Avatar
KYVette90
Default Re: electric water pump ?? (vanduker)
I don't think it would be a huge crisis if your electric water pump were to go out, mechanical ones go out all the time. I wouldn't be afraid of a little fuse blowing either. How often do your fuses blow anyway. I think the electric pumps are a very good idea, especially for racing. This is just my opinion. :D
To electric water pump ??
Old Dec 25, 2001 | 06:36 PM
kkonen's Avatar
kkonen
Default Re: electric water pump ?? (KYVette90)
I have been told to expect about 10 rwhp. The biggest gain you get from an electric water pump is better cooling. The electric is constant speed, regardless of engine RPM. This means that the impeller was designed to operate at peak efficiency at that speed. A mechanical pump does not match the effiency since it must work over such a wide RPM range. Even at peak effiency, it flows less than the electric unit. The only reason I do not have one is that it is illegal for my class.
On the downside, I have heard of more than one person with wiring issues. I don't know the specifics, but I would warn you to make sure the wiring is done properly.
Old Dec 26, 2001 | 03:12 PM
ASRoff's Avatar
ASRoff
Mark
Well said!! :yesnod: I'd also like to add that When the pump does go bad its alot easyer to change than the mechanical pump is. Its within easy reach a couple of 10mm (If I rember correctly) and a wiring plug and presto change-o!!!. If you get a chance to see the impeller design its a jewel!!! its designed to turn at The motor's rated RPM. The stamped steel piece of dung from the factory (remeber profit margin not quality is the factory way) Probably cavatates badly at certain rpm's. By the way I'm an aircraft mechanic if your afraid of electric motors giving out might I suggest that you dont fly :jester they are used EVERYWHERE on a plane :cheers: :chevy :seeya
Old Dec 26, 2001 | 04:24 PM
black_89_vette's Avatar
black_89_vette
So, what makes/models do people use, and how much are they?
