No downshift on 4l60E!!!
Old Jun 21, 2008 | 02:37 PM
Batyrkhan's Avatar
Batyrkhan
Default No downshift on 4l60E!!!
Hello Vette Community,
I need your help with trans again. Suddenly my 4l60e transmission stopped downshift (overdrive) . I am not sure if I am naming things correctly, but let me explain. Usuaally when you you push acelerator on any speed it shoudl downshift to previous gear, BUT IT Do
esn'. Generally trans works fine. I have 95 Coupe.
PLease help me to identify the problem.
Batyr
Old Jun 21, 2008 | 03:22 PM
Pete K's Avatar
Pete K
Scan it. If the tps or other sensor is out of whack, it could cause shift issues.
Old Jun 21, 2008 | 09:32 PM
rickneworleansla's Avatar
rickneworleansla
Default throttle cable
Check the throttle cable for slack. My throttle was down to around 89% and it would not downshift when floored because the PCM was not reading WOT.
Old Jun 24, 2008 | 03:35 AM
Batyrkhan's Avatar
Batyrkhan
Thank you Guys!!!
I hope that is the problem.
Pete, your ray of technical spiritual power should help
Batyr
To No downshift on 4l60E!!!
