where can you find the hose replacement for the opti that sucks out all the mositure. I see that it gots that metal piece in to mate up to the opti. Mine is gauged and has a small hole in it. Or will any hose that is the same diameter do? Just wanting to put my car togther right the first time.
What year Vette? It's possible someone modded the Opti before you got it. The 1992-94 Optis were unvented as O.E.M. The 1995-96 models had the improved, vented Optis.
The vacuum harness for the '95 and up Opti-Spark came from the factory with two protection devices in it.
1) Check valve to prevent backflow in case of a backfire in the intake.
2) Vacuum limiter to prevent too much vacuum at the Opti-Spark.
The intake manifold can easily develop 20" of vacuum.
The vacuum limiter shuts down the vacuum to prevent more than about 2" of vacuum from reaching the Opti-Spark.
With full manifold vacuum of 20" inside the Opti-Spark, I wouldn't be surprised if it would collapse.
So, when replacing the hose, don't forget the protection devices.
