Steering problems
Old Jun 22, 2008 | 08:15 PM
LannyL81's Avatar
LannyL81
Default Steering problems
Okay...'96 LT4...problem is when making any kind of a turn...left more than right..the power assist drops out and then back in at radom. Sometimes it does this sometimes it doesn't.
Did the turkey baster change-out of fluid today. Old fluid was quite brown and smelled burnt. Made no difference. Used the Valvoline SynPower synth blend...but only was able to get two quarts, so will have to flush it anyways.
Soooo....is the problem in the rack or the pump? How do I find out?
Thanks guys
LannyL81
UPDATE: The steering gets worse as the car is driven. It is actually pretty good when cool....not ever going to be cold here in Tucson at this time of the year
Old Jun 23, 2008 | 04:23 PM
LannyL81's Avatar
LannyL81
Just wanted to bump this up as I am not sure which is the problem here.
May be I should just change-out both, new rubber hoses and be done with this job.....
Old Jun 23, 2008 | 04:31 PM
schrade's Avatar
schrade
C4 sleeping sickness in a '96? I thought they got that problem out in the late 60's/early '90's...
Google corvette steering sleeping sickness, until someone here with the answer on that one posts up.
Old Jun 30, 2008 | 11:21 AM
Meloyelo90's Avatar
Meloyelo90
I had the exact same problem in my 95 a couple months ago...purchased the Lucas power steering stop leak and no more issues.
I put some in and drove around, turning the wheel constantly for about 10 minutes. Still had the problem but didn't seem as bad, so I put more in, let it sit for about 30minutes, drove around again turning the wheel constantly in my neighborhood and haven't had any problems since. Pretty sure it's a worn rack issue, and will have to replace eventually but for now it works great.
Good luck...
To Steering problems
