Throttle By-Pass Kit for C4??
Old Jun 25, 2008 | 03:09 PM
Rob10R's Avatar
Rob10R
Default Throttle Body By-Pass Kit for C4??
Has anyone installed a Throttle by-pass kit on C4? Does it make any difference and is it easy to install? Got it today haven't got a chance to install it yet..thanks guys
Old Jun 25, 2008 | 03:26 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Do you mean "throttle body bypass kit"? I don't think you want to bypass the throttle!
BTW, you don't need a kit.
Old Jun 25, 2008 | 03:49 PM
Rob10R's Avatar
Rob10R
heres the link to it---->>>http://www.lt1tips.com/lt1%20throttl...%20bypass.html
Old Jun 25, 2008 | 04:09 PM
TA's Avatar
TA
The only real advantage is that in the future you'll be able to remove your TB without having to mess with a coolant line.
Old Jun 25, 2008 | 04:14 PM
BADDUCK's Avatar
BADDUCK
Throttle BODY bypass. Yes, I've seen those. I just pulled off the throttle body in and out hoses and ran a longer heater hose from the firewall to the front of the engine. It's cleaner and doesn't use those additional parts.
Old Jun 25, 2008 | 05:29 PM
Aardwolf's Avatar
Aardwolf
I just ran a new hose as well, though plugging the hose together would be easy and cheap. Working on the car is much easier. No troubles from it.
Old Jun 25, 2008 | 08:09 PM
floridamale's Avatar
floridamale
I just did mine ran a longer hose use some caps to cover the tube ends. Intake seems to stay cooler & I dont have to worry about the hose going bad any longer.
Old Jun 25, 2008 | 09:18 PM
AZ99's Avatar
AZ99
Ive done it on numerous cars you get 5-7 HP nothing major but I will take 5 HP here 7 HP there it adds up.
Old Jun 26, 2008 | 02:55 AM
Rob10R's Avatar
Rob10R
Okay I looked at the hoses and noticed that they too far apart to be able to connect so I'll need to get a longer hose..I know its an dumb question but what size of the hose do I need? thanks appreciate your help guys!!
Old Jun 26, 2008 | 03:22 AM
Demonic85's Avatar
Demonic85
I believe its 5/8" or 3/4" hose, should say right on the side.
Old Jun 26, 2008 | 10:05 AM
NEVRL8T's Avatar
NEVRL8T
I think Nathan Plemmons has it right in his useless items list:
Throttle Body Coolant Bypass - The throttle body coolant bypass kit is often sold as a magical kit that adds up to 5 horsepower. The kit retails for $20 but contains only three components, an inline hose coupler and two hose clamps. The components of this kit can easily be purchased for under $5 at any local hardware store. The theory behind this modification is somewhat sound but it deserves some explanation. From the factory GM routed a small portion of coolant through a passage in the throttle body for the sole purpose of keeping that throttle body from icing. Apparently in extremely cold weather this is a real problem, but the temperature has to be extremely cold, such as well below zero. GM engineers were probably not considering the car that the engine was going in when this feature was designed. Although the Corvette does much better in the snow than most people give it credit for, it is not usually considered a winter vehicle. For temperatures so low that icing could actually become a problem, the cars equipped with the LT1 engine will probably be parked anyway. The original design intent is sound, but it is not really needed in most cases. For any person living in the continental United States it is a safe bet that the coolant can be bypassed around the throttle body without causing any harm. The question then has to be asked, why bypass it? The coolant flowing through the throttle body can heat the incoming air charge somewhat which can possibly cause a decrease in performance. The benefit of this modification has never been quantified in the form of a proven horsepower gain. The real benefit of this modification is that it allows for easier maintained of the car. With the throttle body coolant circuit bypassed the intake and throttle body can be removed as a unit without having to drain the coolant from the engine, or if necessary the throttle body can easily be removed from the intake, again with out spilling any coolant. This modification takes about 5 minutes to perform and has no ill effects unless the car is routinely driven in sub zero temperatures. I list this modification in this section because the performance benefit is not as great as the convenience benefit, and it can be done much cheaper than the "kit" costs.
Old Jun 26, 2008 | 10:17 AM
BADDUCK's Avatar
BADDUCK
It is probably 5/8" ID but check to be sure.
Old Jun 26, 2008 | 12:34 PM
93lt1fun's Avatar
93lt1fun
There is no need to run a longer heater hose. Just remove the TB hoses and plug the 3 ports including the tee in the upper radiator hose and the two TB ports. Make sure to use hose clamps! You can find plugs and clamps at any autoparts store or you may be able to find them at a hardware store.
Optionally you can get early C4 upper radiator hose or go with an after market flexible metal hosing kit which I did.
Old Jun 26, 2008 | 01:55 PM
Aurora40's Avatar
Aurora40
In that case he means a "throttle body coolant bypass kit" as he doesn't want to bypass the throttle body either!
Old Jun 26, 2008 | 03:05 PM
BADDUCK's Avatar
BADDUCK
Maybe it should be "throttle body coolant inlet outlet bypass kit" because you are not bypassing any coolant.
Old Jun 26, 2008 | 04:03 PM
TA's Avatar
TA
Old Jun 26, 2008 | 05:15 PM
BlackbirdZ07's Avatar
BlackbirdZ07
If you're doing this mod by coupling the two hoses together with a fitting (hose coupler), do NOT use a plastic fitting. I did, the plasic fitting burst under pressure, and sprayed coolant all over my optispark. For some reason, it still runs great!
Old Jun 26, 2008 | 05:59 PM
Aurora40's Avatar
Aurora40
Lol!
Old Jun 27, 2008 | 01:43 AM
Rob10R's Avatar
Rob10R
well I did it earlier got me a longer 5/8 Heater hose and by-passed throttle body..thanks guys for the help..its Friday and its Corvette riding day..
To Throttle By-Pass Kit for C4??
